Drilling hole subpanel
PoorOwner
CA
Can I drill a hole below the bus bar that align with the top hole?
I want to mount it to a stud with 2 screws instead of just top one.
Bert_
NW Iowa
Holes are drilled in electrical boxes everyday, it's fine. I drill holes and put 5/16 bolts in 3r panels all the time when I mount them to grain bins. Sometimes the factory holes just aren't in a good spot.
The only real concern would be that you don't drill holes in the top that could let in water, since this is a 3R panel.
P
PoorOwner
CA
It is installed inside. The other holes are recessed though, that means my hole will just have a gap.
PCustoms
VT
In this case i dont believe its a violation as the manyfacturers allow it.
The mfg allows a hole to be drilled in the BUSS?
Edit: now I see he may be talking about drilling the enclosure.
OP, can you mark up a pic to show where you are trying to drill? I might be missing something here...
manwithtools
Lebanon, TN
Actually the other holes are extended from the back of the box. Make a shim for your lower mounting hole that you drill. No harm, no foul in this case. Probably needs to be 3/16" thick or so.
pattenp
Virginia - USA
You can't add blocking between the studs? I wouldn't like the panel tittering on just one stud assuming this is open studs with no wall finish.
