Drilling holes into my hoist posts?
Notch1988
Fort Saskatchewan, AB, Canada
Looking for opinions... I don't see an issue coming from drilling/chamfering six 1/2" holes into each of the posts on my 2 post Bendpak. I'm building some brackets to hold all the pads/extensions to mount to the hoist.
tarmy
Nor Cal
1/2” seems big for holding that little of weight. I would be very careful with screwing with the structural integrity of something holding alot of weight while I was under it...
Ask the manufacturer if that is acceptable...and if it voids the warranty...
bob15
Northeasten, CT
Contact Bendpak. Maybe you could clamp a piece of superstrut to the lift and hang your stuff from that instead.
finn
The UP, God's country
1/4” will hold anything you want to hang on the posts, within reason.
Be careful, though. There’s not much clearance between the carriage and the post.
coljar
Belpre, Ohio
On my Bendpak, there are 3/16" thick sheet metal panels on each of the bottom 3ft. or so of the outside part of the posts. They don't do anything structurally, so I can drill into them all I want. Have they changed the design on later models and done away with these panels?
PT Doc
You could likely clamp some flat bar with some U bolts to the post. I wouldn’t drill it just because I would likely want to change the location about 1 hour later. :)
N
Notch1988
Thanks for all the opinions. I'll give Bendpak a call in the morning. Everything they've attached to the hoist has been welded to the columns so if that's a better/recommended route from them then I'll do that instead.
Ironcrow
Arizona
Benpak is just going to poop themselves. I wouldn't bother to call them. They've got no reason to say anything other than don't do it everybody will die. Other than that, a few 1/4 inch holes to hang some brackets are fine. Do what you want to do.
mrobins297aaa
south east michigan
I vote for welding, the columns are plenty thick enough that a little welding isn't going to hurt them.
I have welded brackets for my air hose reel, ext cord, drop light and electrical boxes to the columns
Jazzman442
Tampa Bay area, FL
Do not dill into your 2 post. Like all other said. Weld, magnets That is what I use or clamps. Look around there are some options for this. Doesn't Bend Pack make a holder for these?
rburke65
Canfield, Ohio
I would pass on the drill, and tack weld a bracket or a piece of unistrut. I don’t think there is much thickness there to begin with.
N
Notch1988
Thought I'd post an update. Decided to weld them as there are no holes drilled in the columns, every attachment is welded from Bendpak so I did the same.
sreeb
SoCal
I drilled and tapped for #10 screws. Just avoid the corners where bearing pads ride.
bad_idea
Pasquotank, NC
Did you call Bendpak? I'm with you on the welding, do not see a structural concern. But, I am curious what Bendpak would say. If they would void the warranty for that.
N
Notch1988
Nice job. I would have rounded the corners on the shelves. I can see me gouging myself.
Yeah I don’t know why I didn’t design them with rounded corners but they only cost $5 each from the laser cutting place so I may just remake them. Honestly I don’t find I get that close to them because of how big the base plate is, you would need to step on it to get close enough.
N
Notch1988
No, I know how that conversation would have went. I just made sure I didn’t pour the heat to the column, didn’t even bubble the paint on the backside.
My hoist is 5 years old so I wasn’t too concerned with warranty.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
ROUND THOSE CORNERS!!!!! Those sharp corners will slice to the bone.
Also what you can do is wrap the edge of the sheetmetal with the strips that come on bandsaw blades. I'm talking the type that comes on the blades that fit larger horizontal saws. The plastic edging that protects the teeth in shipment is ideal for sheetmetal.
CJseven
Southeast Missouri
You could have used Click Bond studs also.
https://www.clickbond.com/mr10
WaterBoyz
Northern VA
tack a section of uni-strut? remember, you can pick up a fully dressed big block with the transmission with the four little carb studs....
Many many many years ago, there was an article in a car magazine that gave the engineering reply as to how those 4 tiny 1/4" stud and nut can support so much weight.
Actually, it was shocking to point of being almost unbeleivable. But was true.
fsae0607
San Fernando Valley, CA
You'd be surprised. The load gets shared between the male and female threads and distributed along the engaged thread area. This is why threads can handle a lot of load.
Here's from my Machine Design engineering book. This is the thread area formula:
Thread Area = (0.5) x (pi) x (pitch diameter, inches) x (Length of thread engagement, inches)
So you see, as you add thread engagement, it gives you more area to take the load. Same with going up a fastener size.
Nerd moment over, lol
