Atlascycle
Get a 3/4" Step drill if using a hand drill, go slow as the steps start to get larger and use lots of cutting fluid.
Jason
Jason
Yes, the hole saw is the way to fly for one off projects of this type, I use a battery drill, sometimes even water but usually a few drops of Tap Magic or Rapid Tap. A few drops every 1/8 of thickness. I have drilled the 3/8 in as little as 35 seconds but those 3/4 thru 2 half inch green plates took about 5 minutes a piece with break, done in place. I recall it took maybe half an hour to drill 4 sets of holes and one battery change.
!!!!if you want them to be fairly true, use a hole saw, if it's not a big deal, use a drill bit. Either way is no big deal. I drilled 20 holes through 3/4" plate with one 5/8" holesaw.
I used to drill 5/8" hole through truck frames all day long when I was building dump trucks. I would never use a hole saw. I always made three passes 1/4" first 7/16" next then a 5/8" tapered reamer. did the same for 3/4" and 7/8" holes. you have to use the big 7/8" chuck riding drill to do it though. just go slow and use a ton of lube
How is WD as a lube for something like this?
Thanks guys, I'll try a lenox hole saw I know their blades are tough.
It took you five years to decide?![]()
