I've done some searching and found some info, but haven't gotten all the answers.
I have a coupe broken bolts in an engine I bought. They are below flush, and I honestly don't have the skills to weld anything here. I've been going at it with some cheap 7/64" Ti-coated drill bits just to get the holes started, but these bits don't do much damage before they're done. I'm OK buying better bits if they'll last longer. I'm using Tap Magic cutting oil. I assume the bolts are somewhat hardened, at least grade 8. Guessing 1 is 1/4" and the other is 5/16", or maybe #10 and 1/4"? I haven't put a caliper up to them.
Am I being too aggressive with drill size? Should I start smaller?
What RPMs should I be drilling with, and for what diameter drills?
Any recos on drill bits? I see some Cobalt bits on Amazon, not many carbide bits. Would prefer to buy multiples of the same size, rather than have a set of different sizes. For most jobs I can usually get by with the cheap gold Ti bits I buy in bulk.
Is there a better cutting fluid to use?
Any other advice?
Any other advice?
