rickpaulos
I need to make a new pin for my garden shredder/chipper. The parts diagram calls the part a pin so that's the term I'm using. Round rod or shaft or axle.
The pins are 8 & 11/16" x 1/2" with one hole drilled for a 3/16" spring dowel pin.
I previously (2015) broke a pin at the spring dowel pin hole. I bent another yesterday when the spring dowl pin fell out and the pin slid out of one end of its holder.
two questions.
How can I tell what grade of steel was used for the pin? I believe it is harder than just mild carbon steel.
And how hard is it to drill a hole for the spring pin? I don't have a drill press, just electric hand drills and a bench vise.
two questions.
