Dripping tap
northerngmc
Whitehorse YT
ImageUploadedByTapatalk1423944509.038737.jpgImageUploadedByTapatalk1423944523.003608.jpg
I am working on fixing a dripping tap set in the ensuite bedroom in a house I am renting.
It looks like I need to remove the black rubber cover/wall seal to get the cartridge out. They are old and hard so I think that means cutting them off.
Can new ones be bought?
I thought I had better know before proceeding. I don't want to end up renovating the bathroom, but the dripping noise is keeping me awake at night.
kbs2244
It is a rental.
Just let the hose hang down to the floor.
No more drip.
tipsy
Speedwell, Tennessee
While I agree with kbs2244 I am wondering if the back of the shower stall is accessible? If it is then that faucet is easily replaced with brand new from menard for about $30.
c4cruiser
Lacey WA
You're the renter?? Then call the landlord to have the problem fixed. It's his house.
If, in your attempt to fix the drip, something goes wrong, then you may wind up having to pay much more for repairs and explain to the owner what you did.
Slednut
Washington state
I own rentals, call your landlord. Yesterday I replaced a faucet on a claw foot tub because it was worn out. It's part of being a landlord.
Worsedog
Central FL
This. Your rent pays for you to not fix house ****.
N
northerngmc
Whitehorse YT
While I am a renter it is a private deal and I am living in a buddies house while he and his wife are off at school. As a home owner I am used to puttering in my own house, so I kind of miss it. Under a normal rental situation I would not be messing with someone else s house.
No, the back side of the shower is not accessible, and I realize that changing the tap set means a bathroom reno.
I was hoping I could take out the cartridges and rebuild or replace them. But the hard rubber wall seals will need to be replaced and I was hoping I could find them online as my local hardware store does not have them.
Thanks for your input.
6768rogues
Western NY
That is why the faucets are typically put on a wall with access from the other side. Even if it means blasting through some wallboard, it is no big deal to fix.
crf731
If you are the renter, call your landlord and let them worry about it.
Problems like that with the house you are Renting are their responsibility to repair, not yours.
tipsy
The pic looks like a freestanding shower stall that would give minimal acces to the backside for faucet replacement but if not, ok. In that case, that black ring or collar is removable. It is a mounting ring and should come off. It may take some pb blaster or liquid wrench soaking but it is removeable. However, I believe it does not need to be removed. The faucet cartridge should be removeable without removing the mounting collar. Soak it in rust remover.
N
northerngmc
Whitehorse YT
Thank you.
I am thinking that the collar would have originally been slipped into place and is a friction fit. But being 30 years old I doubt it is going to come out without snapping. This is fine if I can get a new one. How do you think this collar is attached? Possibly threaded?
I looked into the end of the tap thinking that maybe the cartridge would screw out but I could not see how. There are no flat sides. I was thinking that once I had the collar off there would be a nut to loosen the cartridge.
N
northerngmc
Whitehorse YT
IT appears that there are 2 shower stalls back to back, the ensuite and the main bathroom tub. So it would mean ripping down that shower stall.
srmofo
SW ohio
You better quit while you're ahead. Or at least give the home owner a call before you find yourself in a bad situation
tipsy
Difficult to tell from your pic, kinda dark. I have been a handyman for 16 years and my experience with these faucets is there is a mounting collar threaded onto the body of the faucet on each side (hot side and cold side) but it is just for mounting. There is usually a faucet cartridge collar that is threaded on and once it is removed the cartridge is able to be pulled out. It usually has a couple tabs on it to make sure it stays located in the proper spot. I will see if I can find an illustration reference for you.
tipsy
Can't find any breakdown pics but I will say that parts can be had online. Search for "mobile home shower stall faucet parts" and several websites will come up.
