Drivesolo's Garage Build
Drivesolo
Renton, WA
I’ve been lurking on Garage Journal for a little while now and I finally have something to post. Last week we closed on a new house. We’re super happy w/ it and what’s got me even more excited is that it has attached garage that’s a ‘blank slate’. I’ve got some plans for it and I’d like to get most of them done before the summer. We’ll see how they turn out as I attempt to find the time and $ to execute them. I’ll be documenting the build on this thread as they happen.
The garage is a 19.5 x 37 ft, 2 car + shop or a 4 car (depending on how you look at it). It’s got nice high ceilings that are 10 ft tall, three beams that span the width that are 8’ 7” at the lowest point. The absolute lowest point is at the front of the garage which is 8’ 2” at the bottom of the door rails. The walls are all insulated and painted as well as the door. The builder told me that the walls were painted w/ the same satin interior paint that they used for the living areas in the house, so I’ll definitely have to repaint. It’s a shame since it was just painted less than a month ago. Windows along the north wall are about 7 ft off the floor. Not practical for looking out of or opening for outside air, and are only intended to allow more light in.
There’s a doorway to the backyard which will be good for additional storage in the form of a shed (one of the projects on a very long To-Do List). The builder went the extra mile and did extra mill work for the doors in the garage. Absolutely unnecessary for a garage IMO, but a nice touch none-the-less. The raised door is the one that goes into the house. There are 4 banks of fluorescent lights and the garage door opener light.
There is a cable jack and accompanying 110v outlet about 8ft off the floor on the back(east) wall. I’ve never had a need for a TV in the garage but it’s nice to have the option. There are also recessed speakers in the ceiling. That’ll be nice to connect a sound system too.
This is the paint scheme that I’ve chosen. The grey will be on the bottom half for about 48” and then white from there to the ceiling. I’ll leave the ceiling as is. The red will be for the racing stripe that will run between the two. I have a rotating laser level to help me w/ the frog tape placement since the floor has a mild slope towards the opening.
Paint and supplies are purchased, enough for 2 coats. I decided on latex exterior paint in a semi-gloss. It should make clean-ups easier and hopefully the sheen won’t be too annoying. I should be able to get in there over the next few days and get it done by the end of the weekend. Due to the Holidays being here, we won’t be moving in until after the first of the year. Sounds like a lot of time to get stuff done, unfortunately there are activities and functions that I need to attend every Saturday and Sunday from not until New Years. That combined w/ having to pack our old place leaves little time to get to the house to get stuff done before we move.
Lastly, this is my assistant (demonstrating the difference between near and far, as seen on Sesame Street). She has enthusiastically agreed to help me w/ the build. I plan to put her to work doing the heavy lifting while I supervise.
gumbudah
Northern Wisconsin
Looks like you've got a nice clean slate as you say, not to mention, the muscle to do the dirty work while you supervise. I had my helpers assist with painting one time. About a day later, my wife found them painting their 2 seat battery powered jeep. my two kids, and the neighbor kid. covered head to toe. hehe.
Make sure to post some pics when you get your paint scheme done.
D
Drivesolo
Renton, WA
It's been a long, busy and productive weekend. Between holiday activites, shopping for new things for the house and assembling new furniture I was able to get some time at the new place working on the garage. I was hoping to get the painting done by now. but I'm pretty close. The only thing left is the fun stuff. Thursday and Friday I was able to tape up the garage and primer coat the exposed concrete wall portions. Its been cold and raining here almost non-stop for over 2 days. Humidity was high over the weekend so it took longer than expected to get the 2nd coat on.
Here's a photo of it as of Sunday morning. I had finished the upper portion of the garage in white. I used a rotating laser level to mark the lower end of the red strip and placed strips of painter's tape at roughly the mid point of where it should be. Rethinking it, I should have used the level to indicate the mid point and then place the tape over that area.
My wife was nice enough to lend a hand yesterday painting the lower portion. It went fairly quickly. A big thanks to her! Now the only thing left to do is use the level to indicate the bottom and top of the stripe and mask them off accordingly.
Here is my assistant at the beginning stages of creating the world's largest ball of used painter's tape. Breaking a world's record takes intense concentration.
D
Drivesolo
Renton, WA
Whew! It took forever to get the racing stripe on but I'm finally done. Had to do essentially 4 coats. Each coat pretty much required a day to dry or some 'encouragement' using a heatgun. I should have primed first, it would've saved me a lot of time and effort not to mention running out of the original quart I bought and having to pick-up another. Here are some pics (taken via my phone, a bit blurry, sorry):
Paint garage walls : CHECK
Now for a little something for the floor:
I have enough for 750 sq ft. The garage is 722 minus the area under the step, hot water heater and furnace. I figure it should be under 700 sq ft that I need to cover so I should be good. I called up Performance Epoxy-Coat to inquire about what I should expect w/ the current conditions (low temps, high humidity) for dry time and working viscosity. I was told that I should expect at least 3 days for it to cure before I can walk on it, viscosity should be fine as long as it's above 40 degrees F. It was painful enough waiting for the paint to dry, this might just may cause me to lose my mind.
Boosted1
Georgetown, KY
Drivesolo,
Paint looks really good, but I would paint the doors also to make them blend in a little more. You could do all white doors and trim to match the top half of your walls or you could do white doors with Gray trim. Just a thought. Cute girl btw.
OccupantRJ
Eastern North Carolina
Drivesolo,
I had the same thoughts after seeing the doors alongside the new paint. They seem to detract from the overall look. Walls look great.
D
Drivesolo
Renton, WA
^ +1. Yeah, I totally agree. The doors and their frames look a little lousy against the white walls. I'll get around to painting them probably some time after we move in.
ambenz
NW Chicago Suburbs
I'll be watching on the side...very cool to be able to make your own.
Oh, I can't wait to see the toys your going to be parking in that garage!
D
Drivesolo
Renton, WA
Prepped the the floor today; I scraped up places where paint and drywall mud ended up during construction. Acid etched the surfaced. Neutralized w/ baking soda then, rinsed, rinsed and rinsed again. I wish I had some boots on while doing this process, my feet got soaked through my sneakers, not very fun having wet feet when it's cold outside. Brought ever fan we had at home over and aimed them at the floor. Since it's cold and (could be) rainy I've left the fans to run tonight hopefully the floor will be dry by tomorrow morning.
D
Drivesolo
Renton, WA
Nice progress! :thumbup: How durable is that floor coating?
All I know about Performance Epoxy-Coat is what I've been able to read from their website, from posts here on Garage Journal and from the experience of a friend that has used it on his floor. For my purposes I needed to keep in mind that it can't be treat it exactly like a concrete floor and can't handle hot items or processes from things like welding. Those are two items I plan to address at some point in this build.
MPH
Drivesolo, I also live in Washington, Graham to be exact. I am at the end of my shop build and I am now trying to finalize what I am going to seal/cover the floor with. If you don't mind me asking, where di you buy your Epoxy-Coat from and how much did you spend?
Thanks MPH
D
Drivesolo
Renton, WA
Thanks MPH
MPH,
I bought 2 kits directly from Performance Epoxy-Coat (http://www.epoxy-coat.com/).
I purchased one half-kit and one full kit which should give me 750 sq ft of coverage.
Both kits: $464.90
United Parcel Service (Ground): $77.95
Total: $542.85
It came in about 4 business days from when I placed my order.
If your avatar is the garage you're building, I am VERY impressed! :thumbup:
D
Drivesolo
Renton, WA
Paint Walls: Check
Epoxy Floor: Check
Done w/ the floors. It turned out alright, I had to rush since the family was waiting on me while I was working. Did it in about 3.5 hours, I think if I would've taken my time it would have turned out better. Earlier today a friend and I taped the doors and laid out the 6 zones where I would be applying the coating to. I should have taped the bottoms of the walls but I think I'll just go over the areas where epoxy got on the walls once everything is dry.
A couple of things I learned from this:
- Spike shoes aren't an option, they are a necessity. I wouldn't see how you could do a garage this size (or any floor of an enclosed sturcture) w/ out them.
- The half kit and the full kit each come w/ only one packet of the grip additive and the flakes. I started working w/ the half kit first and later found out that I had used a lot more flakes than necessary.
- The epoxy becomes more viscous when cold. I started w/ the doors closed was probably about 60 in the garage. Half-way through, I opened up the back door to allow some ventilation. Temps dropped to the mid-40's. It made for a slower application.
- A clean evenly poured line will make the application go faster. Spreading it with the squeegee will be faster and even and the final roll will go more even. It's difficult and time consuming to migrate material once you are at the rolling stage.
- Get comfortable walking around and managing your shifting weight when on the spiked shoes. You can easily twist your ankle. Keep careful attention when pitching flakes, else you may end up slipping and end up dumping a handful of flakes in one spot.... like this:
Once the flakes are down, you can't get 'em off. Believe me, I tried.
So I'll check back on the garage on Weds and post my findings, that should give it adequate time to cure. For the most part I think I'm done w/ the garage until the family and I get back from our trip to visit the grandparents for the holidays. Now that the walls and floor are done I can start getting the shop part of the garage setup. Still working out some of the ideas.
Also, thanks to my buddies; first350 & skoobywrx for lending a hand.
first350
Newcastle, Wa
nice!!! Can't wait to see this in person. Loved the imagery of you almost falling and dumping extra flakes on the floor...:lol:
now comes the best part...car lift!!!
MPH
MPH,
Thank you for the information. I was hoping to find someone local that sold it. But maybe I will have to just order it and have it trucked. Again thanks for the info.
Yes, it is my shop behind my house, though I will have to admit that it is a venture between both my dad and I. We have both shared in the cost... long story, but thanks for the compliment. Doors go on before Christmas and electrical will be trimmed out before the New Year. I can't wait!
MPH
MPH
Drivesolo, looks good and you are right, the golf shoes are must. When it is all done and everything is in your garage you won't even notice the little bit of extra flakes.... especially if you don't say anything to anybody!:lol_hitti
How accurate was their sq ft coverage calculations?
MPH
D
Drivesolo
Renton, WA
MPH
Since I had enough material to cover six 125 sq ft sections, it seemed to be more than adequate to cover each of the 6 zones we'd marked off that totaled about 700 sq feet. I know it is thicker in the one zone that totaled about 100 sq ft, but for the section that was about 120 ft, it covered them well too. Supposedly it's 9.7 mills but the option exists to double up the mix to about 20 mills. I'm not sure if double the cost for double the thickness is worth it. There are some spots w/ in a zone where I know it went on thicker, possibly as much as 20 mills so I'll see how that compares to the thinner spots over time.
D
Drivesolo
Renton, WA
Awww man.... you just gave away the surprise. LOL!
I'll be ordering a Dannmar MaxJax lift when I get back from my trip, it may not get installed until the end of January since we'll need a couple of weekends to get the house in order after we move in.
D
Drivesolo
Renton, WA
I was at the house last night and I checked the floor. It'd been 3 days since I finished it. It felt cured and I was able to walk on it. It feels pretty satisfying to see. One thing I did noticed and did not expect was that in some places the grip additive fell thicker than usual. The effect is a textured feeling of coral. Feels almost jagged like a cheese grater. I guess when Performance Epoxy-Coat say that it provides grip, they weren't kidding. I'm wondering if it could be taken down a bit w/ a sander? Usually I use a piece of cardboard when I have to lay on the ground, but there are always those times when I have to have a seat or even just put a knee down on the garage floor. I'm guessing that over time and usage that this grip wears down but I'd rather not wait for that to happen. Anyone have any experience w/ this?
nathank
West Texas
Garage looks great, and you will love the Epoxy-coat. It makes sweeping the floor a breeze. I have areas of heavy flake concentration in my floor too. There's an art to throwing the flakes and I think I learned it about the time I got to the last half of my floor. hehe
Best part of the thread was the demonstration of near and far. lol Kids are so fun.
D
Drivesolo
Renton, WA
Paint Walls: Check
Epoxy Floor: Check
Order MaxJax: Check
Happy New Year!
I ordered and confirmed the delivery requirements for the Dannmar MaxJax (http://www.maxjaxusa.com/). With some luck it should be available for me to pick up at the Conway shipping dock in my area in 2-3 weeks. That means that there is a possibility I can have it installed by the end of the month.
The main task at hand right now is getting everything in the old house packed and ready for the move which is scheduled for next weekend. I've been rummaging through all the junk in the garage for stuff I will take w/ us to the new place. During one of my excursions I found some old signs I picked up from a local aerospace salvage yard (now long gone). Never really knew what I was gonna do w/ them but figured I could use one for each door as a "Do not disturb" sign when I'm in the garage and don't want to be bothered.
Not subtle enough?
D
Drivesolo
Renton, WA
LOL... that is SO true. If you look at the 6 different sections I did, you can see the progression of my flake distribution skills. Almost akin to the classic evolution of man picture.
D
Drivesolo
Renton, WA
Re: Drivesolo's Garage Build - Day 1
Whew... a big thanks to all my buddies that came out yesterday to help us move. You guys are the best,... The BEST! It surprised me how much cr@p we accumulated over the years. It was pretty back breaking work and I'm glad I won't be doing that again for a long, long time.
The garage looks a mess. It'll be a while before we sort through all the boxes and weed out the items to keep and those to discard, until then the garage will be the "holding area" for a lot of those things.
A extra big thanks to First350 for coming over before the sun even came up to help me w/ the move. And also for sticking around to get what few items I could get in order places where (I think) they belong.
Hardest part is now over, now I just gotta get everything sorted in time for the lift installation.
D
Drivesolo
Renton, WA
It's here! I ordered it last Monday and it was on dock this past Wednesday. it came a lot sooner than I expected. That big plastic wrapped boxy thing in teh back of my truck is a Dannmar MaxJax 2 post lift.
Borrowed First350's BFH (Big F***** Hoist) to get it off the bed of the truck.
Took First350 and I about 20 minutes to get it off the truck and onto the garage floor. It was the single heaviest item that either of us have ever attempted to move w/ an engine hoist. Was pretty fun thing to do and it went smoothly.
Hopefully I can get a hold of a 7/8" masonary drill bit. So far I haven't been able to find anyone locally for under $95. I'll call around some more tomorrow. If I can get enough room cleared in the garage, I'll unwrap it tomorrow evening and possibly install it this weekend. Big thanks again First350, my running tab on favors is probably at the limit, no?
