vtsoundman
Not sure if this is the right section or not.
Contractor used Quikcrete 'High Strength' Yellow bags bags to pour a couple of slabs a the base of my driveway. The lower apron slab is ~6" thick @ 7'x12.5'. He used 3" square galv wire grid (kind looks like fence material) placed on little concrete bocks spaced about 2" from the a base rock base. The upper slab is similar dimension but is only 5" thick. Much less traffic on the upper slab (only into my house).
We have a narrow single land road, our apron is frequently used as a pull off so others can maneuver around. (The total apron is 24', only did half the lower apron. The other half, while cosmetically poor, is structurally sound, and will be replaced after the house reno is completed).
Was this a mistake to use this concrete grade? Sure, I am sure a higher PSI would have been preferred, but is this something I need to have him correct?
