1wheeldrive
- Joined
- Apr 10, 2012
- Messages
- 45
My gravel driveway was put in over a ditch with no pipe or way to connect the ditch on either side of the drive. Water is ponding on the uphill side until it runs over the top of the driveway.
I want to install a small culvert under the driveway to reconnect the ditch that is already there. The problem is, I will not be able to bury the pipe very deep, probably less than 1 foot due to grade/ditch depth. This is a private drive on a private road so I am told there are no code issues. I don't need to move a lot of water, or drain a large area, just need to give the big puddle somewhere to trickle off to.
So here's the question - what kind of pipe should I use? I am thinking I only need 8" pipe or so, could probably even go smaller...I was thinking iron pipe would be best but it's $$ and heavy. Will the plastic or corrugated pipe hold up to occasional heavy truck traffic, considering the pipe will not be buried very deep? Any other ideas?
