Driveway Gate Project
Troutsqueezer
I think it's called California, land of Prii
There have been a few robberies in areas not far from our place in the past few months so we decided that after 30 years of living here it is finally time to put in that driveway gate. Even though it is a lot of hard work to install it myself, it gives me a great opportunity to get out for a few hours every morning and get the ol' blood flowing. It also gives me the opportunity to drag a few tools out that I haven't used in some time.
You wouldn't think it would be much of a problem just to buy a gate somewhere and drag it home to install yourself but around here (central CA.) that is not the case. Turns out that no one wants to sell or build you a gate unless you have them do the installation. Obviously that is where they make the most money. The only place that we could find to make us a nice gate was a business that had absolutely terrible Yelp reviews. Everyone said the owner was extremely rude and unpredictable. The one thing they agreed on however, was the quality of his work. Having no other options, we gave him a down payment and hoped for the best. We gave him all the time he needed and did not press him to adhere to any timetable. So.....three months later we finally got a finished gate. And I certainly cannot argue with the quality.
I had to think long and hard as to how to load it into my truck and haul it home. I decided standing it up and leaning the two pieces together was the best option.
Next I rented a two-man post hole digger and dug the holes. At my age, I need to ease up on the heavy lifting and overuse of the shoulders or I will pay for it. Even so, my neck still hurts from straining to keep the digger from twisting as it dug down.
Since the gates are very heavy, I installed some outriggers to keep the post from leaning. The post is not yet aligned.
Twenty bags of concrete later, the post are steady. It took quite a long time to ensure they were vertical, tops at the same height, facing each other perfectly and at the precise distance from each other to make room for the weld-on hinges and the gates themselves. There's no going back after the concrete.
That's as far as I've gotten. The next thing is to weld the hinges. I plan to suspend the gates in place with my tractor and hold them against the posts using some clamps while I weld.
Will post more pics as progress continues.
RickP
Annapolis, MD
I like those gates - nice job on the posts too. Have you already bought the hinges for it? Our gate uses weld on hinges with a ball bearing to support the weight, and a grease zerk underneath.
If you ever decide to add any additional ironwork, here's a good source:
http://www.kingmetals.com/Home.aspx
ambenz
NW Chicago Suburbs
Love the look of a fancy gate, it looks very nice.
Looks like those gates you see on TV when they show homes of the rich and famous.
I am sure it will outlast your time on this planet.
The gates look like there setback from the main road a bit.
Enough for a car to park and linger....
...are you thinking of adding a camera, call box in some sort of brickwork in a area in front of the gate with a actuator system for the gate?
A guard shack would also be kind of cool, with tinted windows or a mannequin to greet guests...LOL.
Some private drive and keep out signs might also be prudent.
Looks like a lot of work and a good workout to boot!
Thanks for sharing and keep the pictures coming!
T
Troutsqueezer
I like those gates - nice job on the posts too. Have you already bought the hinges for it? Our gate uses weld on hinges with a ball bearing to support the weight, and a grease zero underneath.
Yes I have the hinges, they are weld-on and very heavy w/ball bearing. I have bought from King Metals before, a nice selection of stuff. I'm ready to weld them on as soon as this rain stops.
T
Troutsqueezer
The gates are nicer than my house. :)
There is a turn around about thirty feet before the gate. I would have put the gate closer to it but the drive slopes there so I moved it up to flatter ground.
I do have game cams set up there along with signs.
I plan on brick columns beside the posts.
Too far from the house for a call box. So far, in fact, that I worry about someone stealing the gates so I plan to weld them so they cannot be lifted out.
RickP
Annapolis, MD
Those brick columns will look great. Nice planning on your part for a very remote installation.
If you ever want to add a call box, I think directional wi-fi could reach to your house. It's not as cheap as wire, but it won't break the bank. I have a gate about 1,000 feet from my house, so I can use wire (although that's pushing the distance limit of cat-5 wire). Fiber optic would also work for you, but that stuff is too rich for my blood! :eyecrazy:
T
Troutsqueezer
Got a little more work done today. Managed to weld on the hinges. A little rusty on my welding but it didn't come out too bad.
Had to flap disk thru the powder coat paint so I had some bare metal to weld to.
Next step is to weld the gates themselves onto the hinges. That's a two man job. I hope I spaced the posts correctly. :drink:
CNGsaves
KS and OK
Looking good !! :thumbup: +1 that you have beautiful property.
Will you be doing anything to prevent "drive around" that might happen to get around the gate ??
Maybe I've got strange OCD or pic is playing trick, but your back axle on Toyota pickup looks like it's too far back ?? :dunno:
Ohmthis
Outside of Louisville KY
I have to agree, that is some very pretty property and view. Great idea with the out riggers on the post. I plan on gates too, but I'm a glutton for punishment and plan on building my own. I also plan brick or cultured stone around the post. Great job!!!
T
Troutsqueezer
Thanks to the wife for holding these gates up while I clamped them to gauge the fit. They're kinda like a motorcycle, let it lean too far and it will keep on going.
Once they were lined up, it didn't take very long to weld them on. I was glad I paid such close attention to the measuring as I was pouring the cement. It paid off when the gates aligned beautifully with the gap between the gates even and the height is perfect. All I have to do now is get the ol' Kubota out and drag the middle of the road so the gates can swing to the inside. After that, it's the installation of the automatic openers. I went with US Automatic brand which seems to be pretty well build. Lastly, I will put in the columns on the ends. Will post more pics as work progresses.
The view outside looking in. The house is up on top of yonder hill.
And the view looking out, where all the walking dead are.
saceone
Montreal Canada
that picture is just incredible.
keep us posted!
Ajustable
Niagara
Very nice gate, the leaves and the flowing top member, suit the landscape, excellent.
I enjoyed your website, Dennis have an artistic hand.
Chris
Bigbandguy
North Carolina
How far away is the gate from your house?... would one of those wireless annunicators work so you would know if someone was messing around with the gate? With something that nice I would be concerned about vandalism.
T
Troutsqueezer
It is about 660' from the house. I've been looking into something like what you mentioned. I think I'm right on the edge, distance-wise. I've got game cams set up down there but those don't stop anybody. Never been any vandalism in this parts in the thirty years I've been up on this hill but that doesn't mean there won't be some tomorrow.
T
Troutsqueezer
Are they just locked by the rams or will there be anything in the centre to lock them together?
Locked by the rams. The control box will handle an electronic lock and I may put one on sometime in the future. If anyone wants to open the gates at the moment, all they have to do is pull the pins on the rams and swing them open. The gates won't stop thieves who are brazen but when they open those gates and come up a hill without being able to see if they are being watched from the house and outbuildings, they are taking a helluva chance. Especially in an area where discharging of weapons is perfectly legal and happens almost daily among the neighbors. There is no way for them to know if anyone is home or not before they breach that gate.
T
Troutsqueezer
A little progress has been made. Got one column foundation poured and ready to pour the second. A couple of hours a day in the morning is all it takes. After that, it's the massage chair, then lunch. Life is good.
I'm almost ready to build the columns. I'm taking the easy way out, using large Rumblestone from PaveStone. All I have to do is stack'em up, put on a cap and an address sign then I'm home free. The wife wasn't convinced that Rumblestone would look good enough. So while we were down at the seller's, I told her to take a picture of three layers of them that I stacked up there in the yard. I took the picture and Photoshopped it into a picture of the gate. I also Photoshopped the address sign and some lions I captured from Google. It's pretty lame but gave her an idea of what it would look like. I'm certain that in real life, it will look much better than this lousy pic because the stacking will be neater and with better coloration and it will have a nice looking cap on the top, etc. Probably won't put lions on it though....
Hpozzuoli
Rhode Island
I am very impressed with how this turned out. You did a great job on uneven terrain. Your photoshop skills are also pretty good.
bgarrett
I like your gate. Mine took me a week to weld up. The spider took most of two more days The center of the web is a 1933 Ford hubcap
BBChevro
Brisbane, Qld., Australia
Very nice looking gates Dennis, they suit the surroundings perfectly.
...Probably won't put lions on it though....
I kinda like the lions. :dunno:
...The gates won't stop thieves who are brazen but when they open those gates and come up a hill without being able to see if they are being watched from the house and outbuildings, they are taking a helluva chance. Especially in an area where discharging of weapons is perfectly legal and happens almost daily among the neighbors. There is no way for them to know if anyone is home or not before they breach that gate.
You could install motion detectors of some sort near the gate that triggers an "alarm" - which was actually a recording of gun fire played through loud speakers up at the house. :lol:
Great work. :thumbup:
T
Troutsqueezer
This morning's work. My Tacoma PreRunner can haul 1,500 lbs in the bed so I am hauling 30 bricks at a time which is a little over 1,200 lbs. I have to make four trips to get it all. Didn't take long to stack them. That's the best part about this particular method.
T
Troutsqueezer
Last pic to finish off the thread. It was an enjoyable project that I spread out over a couple of months or so, a couple of hours about every other day out in the morning sun, listening to R. Limbaugh (sorry, liberals :)) Eventually we will put sort of statue on the tops of the columns. I'm leaning towards griffins or gargoyles. The wife probably wants some sort of lion but we'll see. Still to come is the metal estate sign that we ordered online.
Thanks to those who followed the thread and provided comments.
BBChevro
It looks good Dennis, all it needs now is a fence each side (and maybe a few strategically placed boulders) to prevent "drive-arounds".
Oh, and a couple of lions on the posts. :lol:
(Just kidding).
That is a very classy installation. :thumbup:
bry@n
Ocean County, NJ
Had to smile at that one. Talk about one boring video! Maybe if I put it to music, perhaps Also sprach Zarathustra (theme from 2001 Space Odyssey). dah....dah.....dah! Da-Da! BOOM-BOOM, BOOM-BOOM! I can see it now....
Thanks guys.
well, I have to admit, I was wondering how fast/ slow the gate would open.
Xrunner
Colorado
Looks great! Did you attached the stacked bricks to each other or is it just a simple stack?
