Driving in SS screws
rmanrman
I’m getting ready to install 8 security cameras around my house and garage
The mounting plates require 4 #6x1 inch screws. I’ve purchased SS phillips self tap screws. The steel ones that came with the cameras will rust in a day. What type of screw holder 1/4 inch hex drive can I use with SS bcuse they are not magnetic and I’ll be on a 20 foot extension ladder. Not enough hands to hold drill screws and hold cameras on the ladder. Thanks
rlitman
Long Island
Stainless self tappers with phillips drive. Ha! That's going to be a joy when you strip them all out.
Sorry, but I don't have a good answer for your predicament. The best answer would be to get rid of those screws and get the same in Robertson drive. Or get something galvanized. Preferably with a hex head.
Mongo68
Zap one of the steel ones in to hold everything. Then do the SS ones and swap the first one out last...
finn
The UP, God's country
Use the coated Torx head GRK or equivalent. They aren’t stainless, but seem to perform well for exterior applications, and are rated for pt wood.
engineer2
Chicago burbs
You can get stainless Torx (star drive) at any big box store. A piece of rubber tubing or masking tape will hold them.
jkeyser14
(rural) Maryland
I used the sliding sleeve driver on mine. Still managed to drop one while up on a 32' ladder. So that camera had one less screw now.
johnnyradiant
Vancouver, BC
or snap all the heads off
mcbane
California
Stainless takes time, and if you dont have the time maybe dont use stainless. If you have the time, drill a hole, use a gun tap, then put in the screw. Otherwise, use zinc electroplated screws that will likely outlast your security cameras.
Firebrick43
West central Indiana
He already has the screws.
Use a little piece of tape to hold the screw to the bit to start it.
Every ones point is that stainless screws with phillips drive are next to useless. The soft stainless strips out and cheap ones(which will be if their phillips drive) the heads pop unless pre drilled and carefully driven.
I use quite a few ss screws and only the robertson drive ( square) and torx ones are worth a damn.
rlitman
Long Island
+1 I find that the torx are most resistant to stripping, but I specifically recommended the Robertson, because they stick to the bit best.
ishiboo
Oshkosh, WI
Yep.
I no longer use stainless screws for this. They strip out or snap off wayyyyyyyy too easily. Any quality coated STEEL screw will do.
A few years ago I bought out a few 5lb boxes of 3-3/4" stainless deck screws (R2 drive) that were on clearance. Biggest mistake of my life. Anything you want to use them for the heads strip out before they're driven close to flush.
I have a huge love of stainless, but for fasteners like this they simply aren't the best choice as wrong as that seems.
CTyankee
CT
Yep.
Torx only for SS screws or you're just asking for trouble..especially when you get into the larger sizes.
