SuzukiGS750EZ
- Joined
- Apr 26, 2012
- Messages
- 3,273
Ok. I have one circuit that runs two bedrooms and a set of lights for stairs and a set of hallway lights and I think the bathroom. Mostly just lights, led. I drop ground in one room.
In this room there is a switch, a fan and the offending outlet. The switch is grounded to both the box and both Romex cables. The outlet is grounded to the fan, the switch and the other cable going in, the box is an old work type box. The switch is a metal box and the fan is a metal box. I just went over all 3 boxes and all grounds are twisted together, tight and wire nutted. The fan alone has three grounds.
With the fan off, the outlet has ground. As soon as the switch is thrown for the fan, no ground. Fan/ fan light are switched, outlet is always hot. What am I missing here? I have triple checked all work. I don't know if ground was present before this so I have nothing to compare to. The other rooms have ground, even with the same fan hooked up the same way.
Help!
Help!
