nerraw117
I know it has been discussed in the past but what's the recommendation for a good value 14" dry cut saw? Still the evo 380? I saw the ironton on sale in the hot deals but haven't seen one on sale lately.
Some details about your intended use case and budget would be helpful. Also, are you willing to look at used or new only?I know it has been discussed in the past but what's the recommendation for a good value 14" dry cut saw? Still the evo 380? I saw the ironton on sale in the hot deals but haven't seen one on sale lately.
I should have gave more information. I have a portaband with a swag table but I find it easier to cut 90 degree square cuts with a chop saw. I wont use it much and dont have the floor space for a dedicated large bandsaw. I have a abrasive chop saw and while it works I was wanting to go to a lower rpm dry cut.Some details about your intended use case and budget would be helpful. Also, are you willing to look at used or new only?
And finally, if you have seen these threads before, you should be prepared for people to talk you in to buying a bandsaw instead of a dry cut saw. Might be helpful to state up front whether you would consider that or if you're absolutely set on a dry cut saw.
Gotcha. That helps. I swear this will be the last thing I say about bandsaws, but I just want to make sure you're aware of the benchtop horizontal bandsaw options. They don't take up any more room than an Evo saw, are light/portable, (can) cut straight, can cut very precise miters, and blades are cheap (compared to a TCT saw) , such that you can keep different blades handy and swap for specific tasks (solid stock, thin wall tube, aluminum, etc.) and finally, some are variable speed.I should have gave more information. I have a portaband with a swag table but I find it easier to cut 90 degree square cuts with a chop saw. I wont use it much and dont have the floor space for a dedicated large bandsaw. I have a abrasive chop saw and while it works I was wanting to go to a lower rpm dry cut.
I have nothing against used items specifically because I am cheap lol
