Dry time before applying epoxy
M1AHD
Hi Everyone, I was curious as to how long it took for your concrete to dry after power washing/etching etc. ?
I spent 2 days cleaning/washing/etching/rising my garage floors. It has now been 4 days of drying and I can still see some wet (darker spots) in several areas of my floor.
I know to perform the moisture test (duct tape plastic sheet down) before applying epoxy to check for moisture in the slab. I haven't even bother to do that yet, as I can visually see there is still moisture at this point.
Really just curious as to how long I should be anticipating.. Guess I really soaked my floor good.
Drying method has been leaving the garage door open sun up to sun down. Avg daily high 70f and 35% humidity.
Just today I rented one of those carpet blowers to help move some air across the surface.
LegacyIndustrial
deerfield, IL
The fan is a great idea. Air moving over the surface will wick away the moisture.
Pressure washing is effective but it does slow the drying process.
Sent from my iPad using Tapatalk HD
tncatadjuster
Memphis, TN
It should be dry on the surface by now.If it takes that long for the surface to dry visibly, then look for moisture from below. I can usually coat in a day or two after having water on it. I do recommend a waterborne epoxy primer, it was exposed to moisture from above.
