Dryer electrical issue
evercl92
Columbus, OH
My daughter alerted me that the (electric) dryer wasnt working right. I went to investigate, got a faint smell of electrical.
I took the outlet out and found one of the hot lines melted into the outlet. See the pictures.
It has been hooked up for 4+ years without issue. Thoughts on what would cause this?
Dryer itself is 5 years old.
Side question - how does the 220v get split up within the dryer? Or does it? As in, does 110 to to the fan / electronics, 110 to the heater?
Wow someone didnt know what they were doing.
As said above, wires are suppose to go inside the lug holes, then the screw lug tightens doen on them.
Thats a tell-tale sign of a loose connection. The wire did not allow the screw to completely tighten and probably vibrated loose...
Do you have an electric range in this house? If so i would check the outlet there as well.
There is a terminal block in the back of the dryer. The heater is 240v. everything else is 120v.
One hot leg powers the motor, timer and controls.
Both hot legs usually go to a contactor or switch that controls power to the heating element.
BTW its 240v not 220v
exranger06
CT
The heater is 240V. The electronics, fan, and the motor that spins the drum run on 120V.
