jpcjguy
Hi all,
So I am nearing the insulation and drywall stage of my detached. I have 4/12 inside pitch scissor trusses over the lift bay. They are 19.25" on center.
I was noticing the good amount of sway there is in the bottom cord of the truss. I can move them back and forth pretty easily. I can run 2x4s across them perpendicular on bottom cord to make them more rigid, but then it makes insulation more of a pain. Plan is to staple kraft faced R38 or R49 between the trusses.
On another note, when I held my 4' level across the bottom of some of the trusses they were not all flush. One or two was 1/2 - 3/4" lower than the others. What is the acceptable level of variation? I don't want to hire a drywall crew and have them install it and have it be all wavy - and then give them the excuse that the framing was off, so it is not their fault.
