Drywall around garage door
garrett1812
Indiana
Having the garage drywalled and there are gasps between the drywall and the wood frame around the door. Should this be mudded, or would that crack? Or should it be caulked?
Tejay
Caulk or a small flat trim( 1/4x1”) that can be painted the same as the rest.
bwringer
Indianapolis
Trim will look a lot neater.
There's lots of vibration and temperature variation here, so I'd attach the trim only to the wood so that it "floats" over the drywall.
You could stain or varnish the wood to make it look a little nicer, paint the wall, paint or stain the trim, and maybe even end up looking halfway fancy.
Or stuff or spray some flexible foam in the gaps and call it a day.
matt_i
Some quarter round trim would look nice there imo. A little more work to miter and brad-nail it but then paint it up and call it a day.
1969
East Coast
Too late now , but could have used "j" trim...... metal or plastic. Use caulk now.
wssix99
Chicago, IL
G
garrett1812
Indiana
I have that stuff on the bottom of my drywall (where if sits against the concrete stem wall). It looks terrible - all cracked. I asked the guys doing the new drywall about it and they said the mud over it will crack within a year, and they have stopped using it.
Firebrick43
West central Indiana
If glued with 3m 66 and stapled on, then use a first coat of hot mud I have found it to be bullet proof. I add some type two titebond glue for improved adhesion with the first coat of mud with any kind of bead. Much more damage resistant than steel trim. Never had a cracking problem with it. If it gets hit hard it will typically be just a small chunk out of it as opposed to metal bead that will loosen and crack the whole corner. Lazy drywallers using bucket mud for the first coat cause more problems than anything.
Against the stem wall should use the super seal profile at the bottom of the link shown.
