Anyone ever the use the below in your garage? I like to "overbuild" things and am thinking the below would be a good improvement over regular 5/8 dry wall.. Thanks
USG Sheetrock® Brand Mold Tough® AR Firecode® X Panels are available in UL Type DesignationAR, and were designed and tested to off er greater resistance to surface indentation and impactdamage than standard USG Sheetrock® Brand Gypsum Panels. These panels are a low-cost
alternative to other systems for partitions that require greater impact resistance, are UL Classifi edas to fi re resistance and meet the requirements for Type X in the model building code.
USG Sheetrock® Brand Mold Tough® AR Firecode® X Panels have a noncombustible, moistureresistantcore that is encased in moisture- and mold-resistant, 100 percent recycled green-faceand brown-back papers. The face paper is folded around the long edges to reinforce and protect
the core, and the ends are square cut and fi nished smooth. Long edges of panels are tapered,allowing joints to be reinforced and concealed with a USG joint treatment system.
Sold that heavy battery eating thing a while back.
