This is where I get confused. It mentions 32” as the minimum distance to combustibles, however it also has a list of combustibles that doesn’t include drywall. Some further research indicates drywall is considered a “semi combustible.”What does the manufacturer of the heater unit say is the minimum distance?
FWIW my electric infrared unit says to keep it 40" / 1 meter away from combustibles. I suppose that means the front of it, as they also say 16" from the ceiling.
If your wall studs are 16" on center (guessing here), then it looks to me like you've met the 32" requirement.This is where I get confused. It mentions 32” as the minimum distance to combustibles, however it also has a list of combustibles that doesn’t include drywall. Some further research indicates drywall is considered a “semi combustible.”
If the minimum distance to combustible is 32", and you have that, then worrying if the surface is combustible or not is irrelevant.This is where I get confused. It mentions 32” as the minimum distance to combustibles, however it also has a list of combustibles that doesn’t include drywall. Some further research indicates drywall is considered a “semi combustible.”
