drywall screws loose in plastic anchors
peterbrinson
Rookie here.
I'm hanging a bathroom shelf on drywall. I used screws and drywall anchors that came with the kit. But the screws are loose. I tried using Loctite Red to glue them in there, but that didn't work.
I'm not sure if the holes I drilled are too large? (It wasn't easy to squeeze the anchors in there, so not sure what I did wrong).
Anyway, what should I do? Find a better glue/adhesive or bigger screws?
Thank you.
allinon72
Indianapolis
The anchors that come with stuff like that are often junk. I would get different anchors and follow the directions exactly - it should tell you what size hole to drill for the plastic piece.
P
peterbrinson
I agree. One of them crumbled when I followed the instructions to screw them in with a screwdriver.
I could drill new holes, but I'd like to give the current ones a try. I can buy better anchors...and what else?
ty
dogdog
SlowPoke-Canada
London, Ontario
drywall screws have different thread pitch than the wall anchors are made for . use wood screws
I don't think the OP said anything about using drywall screws, he used the included screws & anchors.
You could try the stripped screw hole technique... remove the screw and put a wooden toothpick or a short length of stranded copper wire in the hole and try tightening the screw.
Zeke
Loctite is not the answer. Are the anchors loose of just the screws? You can use a larger screw. You can glue the anchors with carpenters glue. Or superglue. Leave the hole open, of course using a Q-tip to clean out.
Skiff Builder
Southern NJ Coast
For static loads, I like these drywall anchors. you can remove your original anchors and thread these in the holes you've already made.
If you ever hang something that has moving parts, like a door, the above will eventually loosen as time goes on. For those type loads I like a Toggler type anchor.
Bucko
The Toggler type is my go to for heavy stuff where I can't catch a stud. Few things I've learned is to draw the metal bar all the way to the back of the drywall and make sure its not hitting anything before pushing the zip tie type collar down. I also like to add a fender washer on them as well.
stonesfan68
Houston, TX
I get a different anchor system from Lowe’s when my shelf failed from drywall anchor
Toggles type and these screw type seems to work sell on enlarged holes but the best is still finding the stud to mount onto.
I don't use the installation hardware that comes with the product, either. I use either one of the two types above. The anchor screws will most likely work in the existing holes.
TRWham
East Cobb County, Georgia
me bad. misread his post . apologies
I read it the same way, but the thread title is "drywall screws loose in plastic anchors" so it is not unreasonable to have concluded drywall screws were used.
Beauregard
Southern Nevada Desert
75gmck25
Alexandria, VA
I've been using this type of anchor if I have anything that is going to be heavy (radiator, shelves, etc.). They come in different sizes and weight ratings. You drill a hole and then snug them up to the wall with the plastic pull (very easy on the wallboard). Then use the metal screw to mount the item on the wall.
