east_tn_emc
Someone please tell me if I am wasting my time or if this is a good solution....
Garage is 42' wide, with rafters 24"OC. I used 5/8 4x12 drywall on the ceiling run the long way, so each 12' piece spans 6 rafters. The long seams have cracks in them. The tape and mud cracked. I used paper tape and the bucket pre-mixed mud.
My proposed solution, which I have already done about 12' of, is to take 2x4 blocks 22" long and go up into the attic space and glue them over the seam laps that are exposed between the rafters. Then remove the cracked tape and mud from the garage side. Once the tape i removed, I get the screw-gun out and run screws down the joint, screwing down the 2x4x22" block. Then retape and paint.
When screwing down the pieces I have done so far, I am seeing the seams move a little, and draw up tight. Once finished with the screws, pushing on the seams shows no movement between the sheets of drywall.
Will this work to keep the cracks from coming back, or am I wasting my time and effort? My thought is that I am tying the seams together into a solid piece and thereby preventing movement between the pieces, which I figure is leading to the cracks.
Thoughts, criticisms, complaints, (even silly jokes...) would all be welcome. I dont want ugly cracks going across the ceiling of my garage!
