Drywall too much $$$$
overkill 19
Red Deer, Alberta Canada
What is everyone putting on their garage walls instead of drywall.
Up here in Alberta it's cheaper to put 1/2" plywood than drywall. Don't really like the way that looks.
I saw somwere on here somone used metal grain bin sheets on the bottom hafe of the wall, but I can't find it again to show my wife.
Who's got the best system, show us some pic's!!!
cobymedic
I just finished painting OSB in my garage, 2 coats of exterior primer and 2 coats of exterior latex paint. I must say it turned out better then i thought, you can still see the texture of the wood but the paint is uniform.
I'll be posting pics in a few days when everything is finished up.
skeletonizer
I used 7/16" OSB and painted it. Less than $5 US per sheet. One coat of Kilz primer and two coats of flat enamel interior.
It is Norboard imported from Canada... you're welcome. :)
If you are **** about keeping the seems tight it looks pretty good. Remember it's a garage. IMO if it's got walls and heat you are far ahead of the curve, everything else is a bonus.
fatboy99
Indiana
I used 1/4" OSB was going to use 7/16" but it was huricane season and one was heading inland and the prices skyrocketed the 7/16 was almost $18.00 a sheet the 1/4 was $5.00 a sheet i kept the seam's tight and then coated each seam with spackle and lightly sanded came out great was painted with exterior primer and semi gloss paint
Brad
e-tek
Saskatoon, SK
Coby - Gyp-roc was on-sale here (Saskatoon) for 5.99 a sheet (8'). I'm sure you can find the same deal in AB. We just did a reno and paid 25bucks for 12 footers though...
Skeletonizer - Everyone paints OSB white - maybe that's half the problem. Your shop looks great in yellow and some accent colours. BTW - I just bought the same two MOPAR signs!
O
overkill 19
plywood is the same or cheaper than OSB...go figure. I've been bashing the idea of corrugated metal from the floor up 4-5 feet "vertical" then maybe some wood siding, run horizontal. Then a guy can stain the wood what ever color. I'm also thinking that the metal on the bottom would work good for washing the floor.
rieferman
I'm going with plywood or osb based on pricing when I go to the store in a few weeks - like someone said above, I think in a garage setting for my situation drywall will get beat up too easily.
I'm also doing all the wainscotting and trim using the deckboards of oak shipping pallets. Pics when I'm done
bluesman2a
Atlanta, Ga.
If plywood is the same as OSB, then get the PLYWOOD. I did OSB on my walls, and I like it, but plywood will be much stronger for hanging things and what-not. Also easier to paint.
sharpe427
When I did my remodel the sheetrock was way high (last hurricane season) so I ran 1/2 sheets of .250 thick pegboard around the midsection above counter height (3 walls). Saved a bit, and the storage is fantastic! Negative for you cold weather guys is it made insulation a PITA.
Jack Olsen
Los Angeles
The previous owner of my garage did 1/2" plywood all around -- ceiling too. I prefer it to sheet rock, since I can put a fastener anywhere. I can also cut into it pretty easily, which I did when I put in a wall-mounted double-hitch to hold my vise, anvil or grinder. It doesn't look as pretty as mudded sheet rock, but it's a lot tougher.
I would worry about the first time I roll a cart or swing a hammer anywhere near a corrugated tin wall. I don't know how you'd repair a dent, and the pattern of the metal is going to make those dents really stand out. It's also going to bounce sound more than wood or sheet rock. But if you're careful with it, I guess it does have a cool look.
O
overkill 19
I like this setup a lot.
Does the corrugated metal need to be grounded though?
I like the corrugated metal, very cool! I was planning on installing my plug -ins above the metal, just for a ergo stand point. Plus being able to pressure wash the floor and the metal wall. Did you seal the metal to the floor? I like the trim you put on the seams, sure finishes it off nice.:thumbup:
I called today to check on price's, 4X8X1/2 drywall=$13.97CAD 4X8X1/2 OSB = $12.97 CAD
O
overkill 19
Looks great and at that price..... I think Your welcome:beer:. I never understand how come our goverment screws us so bad. You pay $5 USD, I pay $12.97CAD, I live 5-7 hours away from where it's made...go figure. Well thats a different thread!! Nice job!
TheShrine
Texas Hill Country
I've had drywall (we call it sheet rock), paneling and, of course, OSB. The drywall is a nightmare to keep clean...no matter what color you paint or texture it. You're either re-painting it or ignoring it, but it ends up looking pretty beat up. With drywall you better "know" you want something on the wall where you put it...and permanently. If you ever decide to move or remove something (a shelf, rack, sign, etc.) from a drywall service you end up with a very noticeable boo-boo. Again you either repair and paint..or ignore it. When you bump drywall harder than it wants to be bumped (it doesn't take much of a bump between studs with garage type activities)...you'll end up with a hole to repair and paint...or ignore. Maybe I am too rough with my garages, but drywall will keep you doing "wall stuff" rather than garage work. With that being said, I like the clean look of drywall. I figured it this way when I was planning The Shrine....if someone is so set on having drywall in their garage, they'll want it looking good to decent most, if not all, of the time. In that case, go for it! At the same time have drywall tape, drywall putty, extra paint, and several pieces of drywall on hand for repairs, and don't forget the extra weekends to repair it. One other thing...have you ever hung something on drywall, and there wasn't a stud where you wanted to hang it, and you had to use one of those cheesy drywall hangers anmd it came lose for some reason and you had this big wallowed out hole in the wall....I HATE that!
As for paneling.............I just don't like it. My other garage had it and it was fine, I just don't prefer it. Is it a deal breaker on a house purchase...NO. Would I put it in one of my garages.....not at this time.
Now OSB, not my first choice but rugged as hell! You can hang anything anywhere and if you don't like it there or plans change, you can move it and you'll never know it was there. My place is wrapped inside and out with the stuff and it's like a tank! Of course, I wrapped the outside OSB with HardiPlank. One complaint you'll hear about OSB is that you'll have a discolored surface under whatever you move when and if you do. In that case I mix up a little bleach and water and spritz the entire area, and with in hours the discolored area is blended with the surrounding area. As for my corrugated aluminum on the walls (GalvaLume), they are merely for looks and serve to break up all of the OSB, and they are not sealed to the floor. Each piece is resting in a channel or 1/2 dado cut into a 2X2 cedar on the top and the bottom. They are basically "free floating" in these channels, with 4 screws per panel for looks. The plan was/is, if I ever have to replace a panel due to damage, I pull 4 screws, lift and remove the damaged panel and replace it with a pre-cut panel that is waiting in storage. I have accidentally banged it much harder than I ever banged my drywall and you couldn't tell unless I showed you. As for the question concerning pressure washing....no, I never plan to pressure wash. All trim through out the project is hand cut cedar. I had initially planned pine, but changed to cedar when I put up a few test pieces. At the time it seemed like a good idea, but I hadn't considered the amount of that I'd have to use nor the cost....but it turned out OK.
Click on this site to see how I used corrugated metal on the ceiling as well. http://www.garagejournal.com/forum/s...tbox&showall=1
BTW, thanks for the compliment!
Nova
SK
Damn, $6 is cheap...... Mcdiarmid had it on sale for $9 a few weeks ago.....I am hoping it goes down that cheap again in the next couple of months. I was quoted close to $14 locally, even having to get it delivered from 40km away was still a significant savings.
cobymedic
Shrine, I love the look of your garage! Gives it that rustic cottage feel but yet it still looks clean and modern for a garage.
Been a couple days now since I have painted my OSB and the more I look at it the more I am happy with it. The paint is totally dry now and 100% uniform. Sure there are a few tiny white spots were there was a little hole or something and the paint didnt cover up the primer, but like someone else said it is garage. I even patched up some old holes in the wall, from the pervious owner, just with a small piece of osb and some filler and unless you look close you will never see the patch. I can see because I know excately were it is, but i dont think anyone else will notice it unless they go looking.
skeletonizer's garage looks great as well, from the pics it is hard to even tell it is OSB.
I agree to, white is the killer. Everyone goes white osb and it doesnt work well.
66 GMC Truckin
I bought my drywall from the local wholesale businesses for drywall such as Winroc or Kenroc. (Winroc had much better customer service skills). I bought damaged sheets that maybe had some slight edge damage or end damage and as a result they were sold to me for $5 for an 8 foot sheet and $7 for a 12 foot sheet. The 12 footers worked good for me since my ceiling is 10' and I just cut a bit off the end on each one. Once I mud the joints you will never see the edge damaged pieces. We did this for our entire basement too and it saved us a lot of money. All in all to to my basement and shop I have about $300 into the drywall. My shop is 26' x 36' and the basement is not too far from the same measurements.
ol55
Glen Arm, Md.
I used drywall and metal on the bottom.
skeletonizer
Has anyone tried using metal siding inside thier garage?....pic's.
I have seen several ceilings done with white barn steel. One shop I know of in the UP of Michigan is barn steel inside and out.
I would be OK using it on the ceiling in a larger building but I like flat walls for hanging things on like shelves, cord & hose reels, etc. Also if you want things like tables or work benches up against the wall you will have gaps due to the ribs in the steel.
BooUrns!
Edmonton, Alberta, Canada
We usually get hosed on building materials up here. Online prices for drywall here list 4x8 as on sale for $13 and 4x12 for $22 ($30 for 4x12 ceiling board).
Prices have not gone down here for building supplies despite the slowdown in the housing industry (we didn't have a crash).
waltmcq
PT
I got an apartment above mine so something to do with the building code I had to sheet rock it
BooUrns!
That would most likely be a 'fire separation' barrier. Theoretically, the drywall will slow a fire enough to allow the occupant to escape... if that person survives the smoke inhalation.
Fueler
Urbana, IL
I used OSB in my shop for the usual reasons BUT I found some at Menards that was smooth on one side. Sanded perhaps? No lines whatsoever. Got the best of both worlds that way.
OldCarGuy
I would only consider 5/8” Firecode Sheetrock in any of my garages. Most local communities require it by code when a garage is attached to the house. Even at twice the price,, having the added fire suppressant is well worth it. I treasure all my toys, and want to protect them the best I can!
I always use lags into the studs when I mount heavy shelves and the like on the walls. When strength isn't as much a concern I use E-ZAncor. http://www.easyanchors.com/Products.aspx?product=tnl&info=features They are simple to install. No need to pre-drill. And have more holding power than you can imagine in drywall.
Drywall surface can be very durable and washable. When it is painted with a high quality semi gloss enamel. All my garage walls are white. That are subjected too all kinds of grease and grim. I simply clean up with a water based cleaners and a rag.
