I need to finish drywalling the garage. The only part left is the ceiling. I have a 15' wide insulated double door. Quite heavy. I need to lower the rails that are attached to the ceiling so that I can drywall under the bracket.
I cannot lower the door and disconnect the bracket from the ceiling since the springs are under tension, right? I cannot lower the springs myself and most of my neighbors and friends are not quite the types to do get their hands dirty.
What's the best way to do this? Block and tackle? Counter weight with buckets and stone?
Should I leave the garage door up and suspend the rail using metal straps?
And yes, the insulation is a bit messy. I will tidy that up as I go along.
Anybody?
Anybody?
