I have two Carrier 58pav070-12 furnaces that trip the limiter whenever they run together. Resetting the switches will give about 15 mins of runtime before tripping again and throwing error code 31 on both units. If I reset the switches and run one furnace at a time, both run perfectly normal with no issue. I’ve disconnected all the vent pipes to the first 90 and cleaned out any dust/debris and checked for blockage. Two story home with vertical vent pipe out through the roof still has cap intact and I can see it blowing smoke when one furnace is running. When it stops raining, I’m going to take the roof cap off and see if there is any visible obstruction in the vent pipe.
Any one have any other ideas? Just seems odd to me that it is only tripping while both are running. Gas water heater is also connected to the vent pipe and has no issues.
