Dual GFCI in bathroom needed?
Model A Fan
NW Washington
I'm replacing GFCIs to a new white color and wanted to know if I need to install two GFCIs here or if one GFCI and one regular/heavy duty outlet would be proper/code.
Please see pic of how it currently is. I have two GFCIs if I need to. Thank you!
Model A Fan
NW Washington
They are on the same breaker. If they're not connected to each other, then I'm assuming separate circuits. Wired together, same circuit I'm assuming?
sparky 1971
Central Iowa
Odds are that they are on the same circuit and the GFCI is protecting both. Incoming power connects to the line side terminals and outgoing to the other receptacle will go to the load side. When installing new, the load terminals will usually have a piece of tape over them. You can replace them as is, but there is nothing but price stopping you from installing two GFCI's. If it is two circuits, you will need two GFCI'S, but I doubt that's the case.
The easiest way to tell if the standard receptacle is on the GFCI is to hit the test button and see if they both quit.
rdoty
Massachusetts
There is probably a double pigtail on the line in - a "Y" connection with each outlet connected directly to the line in through the pigtails. In this case the outlets are independent and you would need two GFCI outlets.
If you wired it with line in to the GFCI outlet and a wire from the out side of the GFCI to the second outlet you would use one GFCI outlet and one regular outlet. This would be the cheapest option.
dave*99
Coastal NJ
I hope not. That would be a code violation and an obvious mistake.
dave*99
Coastal NJ
Can you explain this? A double pigtail is the most obvious way to wire a quad outlet.
Don't think of this as a quad outlet.
Normally there is a line in to a GFCI followed by a second receptacle (or more) connected to the load terminals on the GFCI. In this case the GFCI and following receptacle are located in the same 2 gang box.
If it was wired as you described with a pigtail off the incoming line connected to the GFCI AND the other receptacle, you would have an unprotected receptacle. Not good.
GFCI protection is required in the bathroom so it would be a code violation to wire it like this and it would be odd to do so since the GFCI is right there.
Wiz02
Southeastern PA
Bringing this thread back for a best practices question. I have 1 gfci outlet in the bathroom and I am adding 2 more outlets above and on either side of the sink in a tile backslash.
I know that I can feed the 2 outlets off the first outlet's load side, but is this best practice, or do people add 2 gfci outlets?
mike93lx
Richmond, VA
Just install thenm downstream of the GFCI. Using more than one in the same room does nothing but cost you money.
In my house, I have a single gfci feeding bathrooms on two floors, which is annoying, but a gfci trip is very rare.
Wiz02
Southeastern PA
Thanks, saving money always helps. It's an upstairs bathroom with no easy access to the basement or I would run a new line, because the house dates back to when all gfci protected outlets were on a common breaker.
Thankfully trips are rare as my basement outlets and the other bathrooms in the house, are on the same circuit.
