Instead of cutting off a foot of my posts, why not just add a second skirt board? Unfortunately, my metal for the sides is already on site. Thoughts?
using Tapatalk....In Renton wa, and i can't change my location from the app......
Um, what? This sounds like the back end of a conversation I missed the first half of?
Did you have to get engineered drawings and permits/approvals of the design from the city or similar? If so, THAT would the reason to stay with it.
If not, or not yet to that point, I’m sure you could add skirt boards and effectively raise the walls higher.
You’d need to use PT boards for both skirts or you’ll be stuck with having to paint the exposed wood every couple of years.
OR you might consider what I did.
I don’t know what your current plan is for the wall to roof transition but I had started my build plan with only the most basic roof corner, no eave, no overhangs at all and using 14’ wall sheets. This would create a 13-4(?) ceiling.
I later changed to a 12” eave AND soffits. I made this change and then, instead of shortening the wall sheets (and keeping the ceiling height), I kept the wall sheets the same and raised the ceiling to accommodate the eave/soffit.
The inside ceiling height went to 14’2” with a single skirt board, 14’ wall sheets but of course the roof panels gained a bit and added fascia and soffit trim. I just really prefer the eave and soffit look.
