Duct booster into 6" round metal vent
matt_i
Need help with a technique here... I want to put a booster fan in a 6" round metal vent tube to improve the velocity. However everything is finalized and I can't displace the ends or even flex the tube out in the center of the run due to Roxul insulation fitted all around it in a ceiling cavity.
Thinking after removing the appropriate length (equivalent to the inline fan tube), I could then cut two opposing flaps to allow the short fan tube to drop in , slide back to nest on one end and rely on the Carlisle foil grip to seal it all up after a couple of screws.
Is there any other good way to do this? Seems like if I had a wide solid band like a hose-clamp it could also work.
I feel like I'm not the first person to have this issue and there's either a special tool, technique or a fitting that would make life a lot easier!
Thanks for any help!
matt_i
YES! That's perfect. Thanks for the link. I also ordered a booster fan that can fit in a "hatch" cutout of the top and side of the ductwork. It has a rounded half-pipe that then seals the opening.
bullnerd
Jersey
How would you wire something like this?
You would have to tap into the furnace blower motor wiring to have it come on with the furnace?
matt_i
I need to put a clamp meter on the existing furnace squirrel cage blower and see how much it draws. If its minimal as I expect it could be direct wired in parallel with that existing motor. If the draw was too much I could always drive a relay coil in parallel to the main motor (milliamp draw would be additional) and use a separate 120vac circuit for the booster fan(s) power.
However, a multi-zone setup is already in the works, I have a PLC control that's not yet fully wired. But when I get to that point, I will have the "Zone B" thermostat's call for heat to turn it on. I'll do a simple time delay to allow for the purge and the gas valve to open, heat exchanger to heat up, etc. Probably about 30-45 seconds. Could also do an off-delay timer to run after the tstat is satisfied.
So a couple options.
Even if the on
Radix2
the thumb!, MI
I thought those just had a simple thermal switch in them - when the duct gets hot it runs, when it cools off it stops...?
probably something like a 110on/90off switch.
bullnerd
Jersey
That would be a lot easier! lol.
Sounds good op.
Higgins
Shepheardsville, KY
look for A sail switch, vane switch or flow switch is a mechanical switch that is switched on or off in response to the flow or non-flow of a fluid such as air or water. A sail switch typically operates through the use of a paddle which gets displaced due to the force of fluid moving past it.
brewchief
Some furnaces will have an accessory terminal ( often for an electronic air cleaner) that you can power a duct booster from.
Don't wire it to the blower on a multi speed blower, if you do you can get power on that line when other speeds are running and it can be higher than normal, the motor can act like a generator.
75gmck25
Alexandria, VA
I used to have a whole house humidfier that turned on using one of those sail switches. It was very simple - just a lightweight paddle (plastic?) in the plenum, and when moving air pushed it out it turned on the circuit. For a booster fan it could work for both A/C and heat.
Bruce
RoadBeater
South Central, Ohio
I just put one of the add on booster fans in. They make a pressure switch to turn it on. It works well to boost the air flow to my daughters room, which is the furthest from the furnace. It is noisy though.
