cory58
I'm hoping to get some advice from the GJ experts regarding an idea I have for an exhaust fan in my new garage. I've found several exhaust fan threads, but none that address my specific question.
My garage is a 30x50 metal building with 2 large roll-up doors. Walls are 13' and the peak is about 18'. I just had A/C installed, but would also like to exhaust the hot air out of the peak in the summer to keep the building temperature reasonable when the A/C is not running.
Here is the challenge: I don't want to mount the fan on the end of the building that has the peak or cut a hole in the roof. Due to the structure of the building, the max mounting height on the side walls is approx 10'. Since I'm trying to exhaust the hottest air from the peak of the building and the fan (or the output duct from the fan) can only be at 10', I was thinking that some sort of ducted fan would be the best solution. I'm thinking there are 3 options and I am ok with any of them.
1. Fan mounted to the exterior wall with a supply duct run up to the peak. This is what I envisioned, but can't find options made for use with a supply duct.
https://www.globalindustrial.com/p/hvac/exhaust-fans/exhaust-and-supply/tpi-exhaust-fan-10-in-with-shutter-3-speed?trackType=3&trackPrimKey=0&trackCatKey=4449&webCatKey=5463&presentType=3
2. An inline fan like this, but the options I'm finding for this type of fan all seem to be lower CFM for bathroom exhaust or air movement in grow houses.
https://www.globalindustrial.com/g/hvac/exhaust-fans/in-line-duct-fans/in-line-range-hood-exhaust-fans?trackType=3&trackPrimKey=0&trackCatKey=4449&webCatKey=5463&presentType=3?ref=cat/b/inlinefans
3. I haven't thought much about this option, but a fan could be mounted up in the peak with the output ducted down to a hole in the side wall.
Sorry for the long post. I would appreciate any feedback on my ideas. I ran them by the tech who installed the A/C and he seemed to think I would not get the desired result unless I take the traditional route of exhaust fan and corresponding intake vent mounted in opposite ends of the peak wall, which is not an option.
Am I going to waste time and money with any sort of ducted option? If not, what would be the best solution?
Knowing that a building like mine (with roll-up doors) is not even close to air tight, do I need a corresponding intake to get good results?
Thank you!
Cory
Thank you!
Cory
