Duker
Welcome to my welding table build.
First, let me start off by saying I never really intended to build a welding table. You see, the problem/project started when I made the mistake of looking at the VISES of Garage Journal thread and became enamored with all of these great vises GJ members had collected. I never knew I needed a Wilton vise but now I have one. In fact it has been one of the best buys I made off of GJ. Well, the sickness grew and not long ago I found myself searching for another vise and I came across this monster. A Rock Island 597. Did I really need another vise? Did I really need something so big that it gave me a hernia loading it in the back of my truck? Well of course I did and I have learned not to ask stupid questions.
View media item 98748
View media item 98747
View media item 98753
View media item 98754
Did it look this way when I found it? No…. of course not, through my now incurable illness I learned that you need to restore it and paint it to match your garage color scheme. So I did, you will be able to find those before and after picks in my Garage Projects thread when
View media item 98751
I posted them here if interested:
url]http://garagejournal.com/forum/showthread.php?t=100158[/url]
So how does all that relate to building a welding table you ask? Well, the question was now where do I put the vise…. And that’s how it began….
The original plan was for the top to be around 3’ x 4’ x ½”. However, when I went to my local steel supply they showed me a piece 38” x 60” x 5/8” at a fraction of the cost so I bought the piece. Here is the top.
View media item 98707
In the midst of sandblasting…
View media item 98708
Included in the base will be two side cabinet tool boxes. One will hold MIG and the other TIG supplies as well as clamps etc.
I already had a Matco side chest that I have been using on my HF cart but I found another Proto on Craigslist that was too cheap to pass up. The box had a ding in one corner and had the top edge ground off for some reason but for the welding table it would be perfect.
View media item 98710
View media item 98711
Due to the size of my shop I needed the table to be mobile but I wanted something that was still solid enough to pound the living daylights out of something and not move. A friend of mine built an assembly table using these casters from Caster City and it is rock solid so I went with these.
View media item 98712
I am using the top propped up on some saw horses to build the base. Here is the one of the bottom units to hold the tool box.
View media item 98713
Here is how both boxes will be positioned:
View media item 98714
My welding leaves a lot to be desired but I thought this would be a good project to build my skills. As you can see in the photo below I am still a long way away from a “stack of dimes” but I think I am getting good penetration. I am open to all comments if you see something that could help me improve.
View media item 98715
In the next update I hope to have the following done….
I will have 2” x 2” rails between the two sets of legs top and bottom that will also have stretchers that go across to support the tool chests but also some expanded steel I will use in the bottom.
In the top I will build a slide out rail to hold long pieces while cutting with a dry saw that I am going to incorporate a mount for into the base. I will also have built in “trailer” type mounts into the top rails to hold a grinder and assorted other tools.
