Dumb battery charger ?
vpracer
Trying to charge up some dozer battery's. I have a century 200amp wheeled charger. When I plug in and begin charging, on the 40amp setting, it dawned on me to wonder whether the 15amp circuit I'm plugged into will produce more that 15 (ish) amps. So am I getting a 40 amp charge or a 15 amp charge. Or maybe the charger itself has the ability to hit the 40 amps. The amp meter on the charger reads zero, even after a couple hrs plugged in. Batteries are completely discharged maybe?
I'm an accountant not an electrician so go easy on me please!!!
BillK
Beautiful Southern Maryland
If you want a more technical explaination ........ Power(watts) = Voltage x Amps
So 40 amps x 12 volts = 480 watts
480 watts divided by 120 volts = 4 amps
That is in a perfect world and there will be some losses etc but close enough
V
vpracer
Oh yeah, the old 12 v vs 120 v deal. Ah ha. I knew it was simple, that you gents.
Lelandwelds
Central Texas
Off topic, but, does anyone know where to get a dumb charger? Other than building one? Having a battery charger that only recharges "slightly discharged" batteries doesnt help when you have knocked Richard in the dirt.
jvitez
Big Sky Country, Canada
...The amp meter on the charger reads zero, even after a couple hrs plugged in. Batteries are completely discharged maybe?...
Check the voltage of each battery. If the voltage is very low the batteries are probably in need of replacement (11.5 V gives about 10% charge, meaning a sulfated battery if it's been like that for a while).
Can you open the cells and check the specific gravity with a battery hygrometer or are the batteries fully sealed? Are they old?
You may want to leave the charger on overnight. A very discharged battery will accept minimal amperage until it starts to become partially charged, so it may read higher after 8-12 hrs.
Buy a good 12VDC power supply like one of these. You will need a decent DMM to set the voltage.
A lead acid battery will not start charging until about 13.2V 14.0-14.5V is not unreasonable, assuming that the plates are fully covered in acid AND you have a timer on the power supply !
Bert_
NW Iowa
I've never had trouble finding one:dunno:
The main charger I use came from bomgaars, bought just a couple years ago. It's a schumacher 10/30/200 amp unit. Also have a 6/10 amp unit that I found a bunch of years ago.
joe_padavano
Northern VA
Amen. Why are "smart" chargers not so smart? Thankfully, I still have my ancient "dumb" battery charger that's been working great since the 1970s. The "smart" charger I have usually claims that there's a fault if the battery is really discharged. No such problem with the old charger, and the allegedly "faulted" battery works just fine after charging.
Dragfluid
Pillager, MN
Dad got one in the early 60's. About 12"x12"x12". Weighed at least 20#. 6&12V on one switch, charge and boost on the other. We still had a couple tractors that had a single 6V, so it worked out well. Man, that thing would really get something cranking after a short while.
A couple years later, the folks got into a new grocery store, located in a 200 unit trailer park, about a mile from home. Dad made the mistake of borrowing the charger to one of the customers. Well, from that guy it went to someone else, and so on and,,,,,,,,,,,,,,. When dad finally located it, he got smart and took it home and then told people that it didn't work anymore.
I still used it for many years after, until it got to the point of it wanting to charge ME whenever it was plugged in.:shocking:
So I finally had to say goodbye.:(
