Dumb breaker question
Terry D
St. Louis, MO.
No, it is a tandem breaker. It only contacts one leg in your panel. You can only get (2) 120 volt circuits out of it. You would need a two pole breaker, which contacts both legs
D
DavidR8
Victoria, BC
Sorry for the double post, not sure why that happened.
I get why you’re saying now. Thanks
Norcal
So I won’t get 240v if I run a leg from each side?
No, as others have already said, there a couple of obsolete makes, Crouse-Hinds, and Challenger, that would allow that to happen, plus can be done in GE panels with GE breakers, but SQ D HOM twin breakers do not allow 240V loads, as it is physically impossible for anything other then 120 volts, BTW those breakers can only be used in a SQ D Homeline panel, as they have not been UL classified to be used in competitive panels.
Terry D
St. Louis, MO.
The link shows a QO breaker, will only fit in a QO panel
yatg
Southern Oregon
You can put two QO tandems next to each other with a handle tie (QOTHT) for the inner pair. It'll be 240 but not common trip.
D
DavidR8
Victoria, BC
Thanks, that’s what I was thinking about with my original question.
If the resulting 240v are connected to a single device, say a motor and the draw exceeds the 15A capacity would both sides trip?
Terry D
St. Louis, MO.
Looks like that would work, thought you meant if you could get 240 v out of that single tandem breaker. Yes both sides will trip. That is what the tie handle is for. A lot of breakers are not internally connected.
D
DavidR8
Victoria, BC
Thanks Terry, in fact that was the thinking behind my original question until it was pointed out that there’s only one connection to the bus.
I didn’t have a breaker handy or I would have figured that out. Eventually.
yatg
Southern Oregon
From the QO catalog:
"Order two QOT1515 or QOT2020 circuit breakers and handle tie QOTHT for common switching of center two poles."
The handle tie only gives you a common disconnect vs. common trip. If one breaker trips the handle tie is not guaranteed to pull the other breaker off.
When I replaced my panel several years ago, I used regular size QO115 and QO120 breakers with handle ties for the MWBCs.
