kpendlet said:
My panels are back-to-back. By outside disconnect do you mean breaker switches inside the meter box cover? If so, then that's what I have. However, in the inside panel the neutral and ground bars are combined. So I assumed that I needed 3 conductor service cable - 1 for each power bus and one for the neutral bus. Does this sound correct?
Thanks for the replies...
If you have a switch outside in the meter panel that disconnects all power beyond it, this is the SERVICE DISCONNECT. Leaving the load side of the SERVICE DISCONNECT will be the two hot wires (ungrounded conductors), the neutral (grounded conductor) and a separate ground wire. The Neutral, the ground wire and the bare #8 or #6 (depending on service amperage) solid copper wire (required by code) that goes to the ground rod(s) all meet at one point in the service disconnect panel. The "breaker panel" inside, is technically a "lighting and appliance panelboard" and will have a ground bar that is bonded to the metal box or housing and a neutral bar that is NOT bonded to the metal housing, and if it has a jumper strap over to the ground bar, it should be removed. This installation requires four wires, the two hots on the two lugs of the buss bars, a ground wire on the supply lug of the ground bar, and a neutral wire on the supply lug of the neutral bar.
For non-licensed DIY electrical types and even electricians, I HIGHLY recommend owning the following two books.
Charles Millers "Illustrated Guide to the NEC: Based on the 2005 National Electrical Code"
http://www.amazon.com/dp/1401850685/?tag=atomicindus08-20
and the National Electric Code of 2005
http://www.amazon.com/dp/0877656231/?tag=atomicindus08-20
You can, of course, purchase the NEC 2005 directly from the National Fire Protection Assn,
www.nfpa.org if you wish.
Doing home wiring without these books is impossible I've concluded, and in many cases even professional electricians will give you incorrect info as the code has changed over the years and they may not be deeply familiar with the current code.
You can also consult the NEC at the following link. You wil not be able to copy, print, save or otherwise store the info you view, but you can at least read it, from the source. I recommend Miller's book as the code by itself is huge, confusing, and cryptic, Miller provides a through and detailed explaination of what the code covers in both residential and commercial installations. It is very useful in putting you into the right place in the Code itself to read further.
http://www.nfpa.org/freecodes/free_access_agreement.asp?id=7005SB
Please note, I AM NOT a licensed electrician and the advise you have recevied here is worth exactly what you paid for it.............. notta.... zip.... nothing........ Don't believe anything you read on the internet unless you can confirm it from other reliable or accredited sources................
Charles
