rockford33
I haven't thoroughly investigated this yet, so bear with me. I seriously think that they may have not insulated the walls in my garage when the townhouse was built. Last year, I had to have the cable company come out because my digital signal was crappy. Turns out to be the splitter, which is behind the wall in the garage. Cable guy said I had to cut a hole in the wall so he could access all of the splitters and see what the problem was. So I cut an 6-inch wide by 8-inch long rectangle in my drywall. Found the splitters hanging there, don't see any insulation in the wall. I just pulled out the piece of drywall to take a look in the cavity. There are studs on either side of the hole (about 12 inches apart) that run floor to ceiling. No insulation in sight, up or down. Now, this is an interior wall, but I would think it would be insulated since you have a non heated space (garage) next to a heated space (entry hall). The garage is always cold, and is surrounded on three sides by building. Could it be that it was not insulated properly? I am going to try and check the ceiling also, since the living room above is usually not too warm either. Would they insulate around outlets, etc.? Could I pull off an outlet cover and look for insulation nearby to tell me if there is insulation? Thanks for the help guys.
