tinysparky
- Joined
- Oct 22, 2016
- Messages
- 195
Hello,
Looking to start a dump trailer build next month and I can't decide between using Hydraulics or using a winch on a tower to dump the trailer.
It will be 6'x8' and I am looking for a 6k pound capacity. Hydraulics systems look to cost about 4x the winch cost hence the hesitation.
The trailer will be used 6-8 times per year only.
Thoughts?
Thoughts?
'Twas a facetious way to point out how much work it would be using a winch.... BTW, for that type of operation, it should be a worm gear style one, unless you like to take chances with a crank whirling at uncontrolled and blistering speeds should you ever lose your grip with the dump section up more than a few inches from the resting stops...
