Aviatordave
- Joined
- Jul 24, 2015
- Messages
- 58
Hello folks,
I'm new to the forum and am building a 40x80 pole barn in lower Michigan. Trusses are up and steel starts going on tomorrow! I'm really excited!
I'm planning on heating the concrete floor with geothermal heat via loops of PEX in the concrete.
I've been researching different methods of dealing with the discharge water from the geothermal unit. (It's a single pass system being fed from the well.) I live on 10 acres of wooded land. What's the best way to deal with the discharge water? Just let it drain into a downhill run away from the barn somewhere away from the building? Dump it back into the aquifer with a second well a good distance from the source well? What has worked for you?
-Dave
-Dave
). We have a large water softener which leaves salt stains on fixtures and counters if water isn't wiped up.
