Duplex outlet upgrades
Milton Shaw
Buy one and make sure you and your wife can actually plug something into them. Most of the tamper resistant outlets I have seen are almost impossible to actually use. They might not be an actual upgrade.
MEDTECH
Northern NJ
Good points, both of you. Tamper-resistant is not needed or wanted.
I changed a few when I first bought the house in '12. Plus, some faulty GFCIs. All screw-down and working fine. I'll stick with the proven methods.
Thanks, guys.
PCustoms
VT
Thanks, guys.
Yeah, looks like backstab 2.0 with a low price point.
I forgot what level I bought, but it was definitely a few levels above "tract home" and you could tell by the feel it's wasn't junk
acer66
Western North Carolina
I asked the same question a while ago and started using them.
So far no problems and I will use them again.
Stuart in MN
Minneapolis
The Leviton receptacle above isn't the same as the old style backstab receptacles - the Wago style connector is a compression joint that's more reliable than the old style that was a little bent piece of metal that snagged on the wire. However, it's designed to save time during installation - if you're wiring up an office building with hundreds of receptacles that's one thing, but if you're just replacing a couple at home it isn't that important.
Norcal
I'm curious. Were your original receptacles Tamper Resistant as required by 2008 NEC?
If they were installed prior to the 2008 being adopted by the OP's jurisdiction, there is no code violation as codes are not retroactive. During device replacement tamper resistant receptacles, GFCI, and worse, AFCI, requirements are also triggered, but NJ does have a rehab code that make things different then most States.
BrandonV
Arizona
Yup. I've tried pullout tests and amperage tests thru the newer Leviton ones. I'm satsified.
908Jim
I can safely say that Leviton Plus series Tamper resistant outlets are better than the LeGrand TR outlets by a mile and are very easy to insert things into. As for the lever edge system, it's basically just a WAGO style hold down but the outlets are bulkier than regular outlets and they cost 2-3x as much.
I settled on Leviton Plus series TR outlets for most of my home, using regular screw terminals. The lever edge adds a lot of cost that was hard to justify.
MEDTECH
Northern NJ
They were not. Previous owner upgraded most of the electrical...new panel, wiring, outlets, etc. Him and his father did the work. Wasn't completed due to his job relocation.
Before I bought the house, I called the town Bldg Dept to see if any permits were still pending. They said no. And, they confirmed they inspected the electrical upgrade. Since he bought the house in 2007, he slid in under the wire, so to speak.
dave*99
Coastal NJ
When TR receptacles were first introduced, I had trouble inserting plugs. You had to be careful in the order in which the pins entered the receptacle.
My current house has the current version of the Leviton Decora receptacles (with screws) The TR function is much better - especially if the receptacle has been used more than once. So I'm OK with them now. And so is my granddaughter.
sparky 1971
Central Iowa
Under orders from the wife, I've replace most of the devices in my house from ivory to white over the last few years (it takes time) and I've used plain 'ol non tamper P&S 3232W's.
rharman
SoCal
Beat me to it. First thought was that they're backstab with a slightly different approach.
dscheidt
Good tamper resistant outlets work pretty effortlessly, and are basically unnoticeable in ordinary use. **** ones are, well, ****. They're what gets installed by contractors because they cost less.
a few years ago, we were visiting some friends who had just moved. The wife was complaining about the tamper resistant outlets, and how much she hated them, and how she was going to replace them with normal outlets. Her husband noted that every outlet in their old place was tamper resistant, and she'd never complained about them. She said "no they weren't!". He said "yes, I changed them all when <oldest kid> was born".
dave*99
Coastal NJ
I agree. The modern Decora TR are fine.
Recently I changed every receptacle in a house for a friend. He had non TR decora receptacles that I installed. So he saved a buck.....
Then he rented the place on VRBO or Air bNb and quickly learned renters want to see childproof accommodations. So he put the plastic protectors in all the receptacles. And some get lost and now it's a minor maintenance item.
When my granddaughter was born my wife told me to get the plastic protectors. I said we have TR everywhere in the house.. Her response was "We do?"
tworley
Colorado
I replaced every outlet in our 1980s house with TR. IIRC, I am using a leviton brand. We have no issues plugging anything in🤷‍♂️
The outlets I replaced, every single one was backstabbed. There were 2-3 that I remember having loose wiring.
nadogail
Coronado, CA
One of my rentals, built in 1979/80, purchased by me in 1985 started having issues with the plugs almost falling out of the receptacles. Some Hubble receptacles followed me home from work, in 1990. I have had no more problems with weak retained springs. When i first installed the Hubble's the plug was a "Wedding Night" fit
nope. quickwire terminals use a spring to hold the wire in place.
these use a metal plate and lever....
