Duracell = DuraLeak?
visionguru
Chicago
Recently, I kept finding battery leaks:
  • Snap-On 1/4" Techangle. 3 AAA batteries were in the battery holder, not in the torque wrench. 2 out of 3 leaked. Voltages were still more than 1.5v
  • Bosch Laser distance measure. 2 out of 4 AAA leaked. Voltages were all above 1.5v.
  • Coast Headlamp. 2 AA leaked. Rotted the circuit board.
  • Nikon camera flash. 4 AA batteries made a mess.
  • Gardner Bender voltage meter (cheap meter from Menards), just found out this morning:
Same pattern, leaked batteries are not discharged. They can still power a flashlight.
I suddenly realized that all those are DURACELL from Costco. I used to use no-name batteries, rarely had any leaks. This reminds me that last year I had to throw out some unused DURACELL because they leaked in storage. It seems that DURACELL is designed to leak, regardless of usage!
KwikFab
Central Valley, CA
I've had zero leakage on both my Energizer and Duracell batteries, and some of these go in very expensive equipment (including my IR and NVGs).
Although I do make sure to buy only Made/Assembled in the US variants though. I also don't like to leave batteries in anything for too long if it sits unused.
whateg01
doo dah, kansas, usa
It seems to me that the leaking occurs when they aren't being used but have been. I don't recall any new in the package batteries leaking. But when I have found them leaking it's in a flashlight that wasn't used for a few months. I don't use Duracell anymore for this reason. I have had others leak in the past but it seems like most nowadays are better than Duracell. I use Amazon basics and Energizer
V
visionguru
Chicago
Those were "Assembled in USA".
I strongly suggest you check the Duracells in your equipment. My Snap-ON torque wrench battery holder is electronically disconnected, equivalent to plain storage, yet Duracell leaked. Last year, 5 or 6 Duracells leaked in my plastic storage box.
From now on, for anything worth $20+, I'll be using lithium batteres from Energizer, Amazon Basics...., anything but DiarrheaCell.
cleaner
At home
Duracell has consistently demonstrated poor quality with leaking cells for well more than a decade. I have had them send me checks for two devices stored in climate-controlled environment ruined by leaking cells and have had unused cells in factory retail packaging leak as well. Stay away from them. For anything I will leave the cells in in a AA, AAA, or 9V form factor I use Energizer Lithium. To date I have not experienced a leak with the Lithium cells.
Mike007
I was selling thermostats that came with Duracells. I had so many leak and ruin the stats I would just throw the new Duracells out and install a different brand battery.
whateg01
Duracells are garbage. I had a buddy who specifically went with HF bulk batteries because they're carbon-zinc. No alkaline leakage. I wonder now if he had a good point.
For some applications that may be okay. However you will be changing them more often because they do not contain the same amount of energy
mikedodge
I've had far more leakage problems with energizer then Duracell.
I don't leave batteries in expensive stuff or things that are hard to replace or clean if something erupts in them.
Oregon Dave
Having the same leakage problem lately with Dura-cell AAA batteries purchased from Costco; no issues the previous 25 years.
Test ran many brands; chose Dura-cell for performance and longevity; since the leakage issue, tried Harbor Freight's Thunderbird Edge; first battery that matches Dura-cells longevity and no leakage issues after ~6 mo.'s.
reader2580
Minneapolis, MN
I use lithium batteries in pretty much anything that uses batteries. The cost isn’t really that high on an annual basis. One wrecked item could easily exceed the extra cost of lithium batteries.
I try to remove batteries from anything that is only used every few months.
JABgj
So. California
I tossed Duracell some years ago after losing a few devices and seeing others with the same issue.
ronkz650
Denver, CO
They will leak 100 times if installed in 100 things. Not so bad if a flashlight whatever, but in equipment that cost $1000s of dollars a little more serious. Every time I see them in a big display such as Costco I look for the puddle of acid on the floor. Other brands such as the Energizer leak sometimes too, but not 100% of the time. Use Duracell they will leak every time. 75% of the time they leak in the packaging even though the use by date may be 5yrs away. Sad. Cheapest Chinese battery at Harbor Freight rarely leaks vs Duracell. I'm referring solely to alkaline batteries. Huge expense in ruined equipment if you use any of them, but by far Duracell leads the pack in bad.
rharman
SoCal
Modern alkaline dry cells are prone to leaks. For anything critical I use lithium.
That's where I am too... Not had a lithium leak on me, but I only buy lithium when they are available.
I, too, long ago switched to Energizer Ultimate Lithium wherever possible.
Just bought a 4-pack of 1500 lumen flashlights from Costco. Have to set a reminder to swap out the included Duracell batteries in a year or less. They're hybrid but I'm sure the rechargeable battery would be dead every time I needed to use one.
captaindiode
NC
Prior to a regulation passed in 1996, alkaline batteries contained a small amount of mercury to prevent the build up of pressure inside the battery. Today batteries without mercury are more likely to build enough pressure to overcome the seals and leak. This is especially true in devices that are infrequently used. If the leakage (a base) is neutralized with an acid such a white vinegar, then many times the device can be saved. Be sure to flush away the vinegar after cleaning up the corrision.
Max
Georgia
I don’t buy the darn things anymore. I use NiMH (eneloop), beware fakes) and lithium.
bluedog225
Texas
F duracell. And the rebranded Kirkland. What a disaster.
rechargeable, envelop, or take em out.
and shame on Costco.
Mr_B
Reading
Duracell have turned into complete garbage .
I won't use them as leak even from new stored in retail packing box .
dscheidt
Carbon zinc batteries (they’re labeled “heavy duty “ or similar) are both lower energy density and can supply lower power (they have higher internal resistance); however they don’t leak. For low draw, intermittent use applications, they work well, and that’s why they are typically supplied with remote controls.
ATC
VA
Yup, been known for years. I only use Energizer Max
Notgrownup
Snow Hill NC
We sell Pro Cell at work . Been selling them for years and have not had any complaints. We sell them to nursing homes for all the devices. I use them at home .
