Durcraft band saw tension screw replacement
CajunMan89
Where can I find a replacement blade tension screw with knob? I don't have a part number, and have had no luck searching for Duracraft parts for a VS-312
My god there is a boatload of **** websites when searching for that information.
I would figure out what size thread your receiver is, and hope foghorns solution works. if not home grown is in your future.
C
CajunMan89
Would this work?
It might, but it's way too long. I was able to remove the plastic knob, so I'll go to a local hardware store and buy a new one. Surprisingly, I was able to clamp the bolt and by placing a pair of channel locks underneath, rock it up and down until the knob popped off. I got lucky there...usually that's when something plastic breaks LOL
C
CajunMan89
UPDATE: I was able to get a replacement bolt and try out the saw. So far, so good! Since there seems to be no owner's or parts manual available, does anyone know of a way to cross-reference the tires and belt for the wheels? I may have to replace those if the blade starts slipping off again. I'll attach pictures of what the wheels look like.
Also, I'm trying to learn a little carpentry and build small things as a hobby. Would there be anything close to a manual available to teach me how to use the adjustments on this particular machine? I noticed there's a metal wheel behind the blade guide, and I don't know what that's for, since the blade doesn't align with it.
IMG_20211118_153950[1].jpgIMG_20211118_153659[1].jpgIMG_20211118_153757[1].jpgIMG_20211118_153900[1].jpgIMG_20211118_153920[1].jpg
