Duro-Chrome 678D Questions
misterbill
I picked up this Duro-Chrome 678D 1/2" ratchet recently along with some other nicely oxidized bits. Two questions:
1. How was the selector held on? Were the corners of the selector shaft peened over to hold it?
2. How difficult would it be to make a replacement selector do you think?
Bill
bonneyman
Desert SW
Nice ratchet!
Yes, the corners are peened over. It's not too difficult to fashion a selector knob. Depending on how close to looking original you want.
misterbill
Nice ratchet!
Thanks, b-man. Anybody have an exemplar and a micrometer handy? How thick is that selector?
Bill
Bill,
I had one where the original selector was still in place but loose. I made some effort at peening the selector shaft to tighten it up with no success whatsoever. I suspect that during the original manufacturing process they used quite a bit of force with a press to do the peening.
DadsTools
I had one of these before. They did a piss poor job attaching that selector. But it's also one of those rats that they pressed together, so the thinking here was probably cheap cheap cheap.
bonneyman
Desert SW
What I've done is get a strip of stainless steel the right dimensions and carefully square out a hole in one end that's SLIGHTLY smaller than the square post on the ratchet. Then - using some old sockets - I press the selector on in a vise. It's the metal in the strip that gets distorted - alot easier than trying to mush out the post. FWIW
