Dusk to Dawn lighting issue
ripperd
Twin Cities, MN
I have been battling trying to get dusk-to-dawn lighting working well on my home/garage. Perhaps some of you know of products or solutions that work better.
The home is a typical split entry, 3 car garage on one side. Garage has 3 decorative lights that I want to be on dusk-to-dawn. These are not very bright, just enough to cut the darkness. In the entryway I also have your very typical entry way light. The garage lights are wired up so this light controls them.
I have tried 2 different "dusk to dawn" lights in the entryway and tried my own "dusk to dawn" labeled photosensor and darkness is picked up wayyyy too early in every scenario. They stay on until almost noon, and turn back on in the late afternoon. Part of this is probably the fact that the entrance faces east and is covered. So ambient light here is already much lower. But it can be middle of the day and a small rainshower comes by and my friggin lights turn on. It kills me and I'm sure the neighbors think I'm weird.
Getting to/from the entrylight box with an electrical wire so that I can do a remote sensor would be a major chore. There are no unfinished areas nearby to fish a wire through. What I was kinda thinking might work would be a drop in replacement for my lightswitch that has an electronic dusk-to-dawn calendar put in it. Something like where I put in my latitude and time zone, and bam, its exact, every time, every day, all year. Does such a thing exist? Or do I need to create it? Something programmed is not entirely out of the possibility, I do have a few things at home doing GPIO hooked up to beagleboards and such. But I'd rather use a off the shelf product if possible.
Thoughts?
wbrian63
Houston, TX
I bought something like this (I think off Amazon) for my mother's house. Exactly what you describe - you tell it where you live and set it for dusk to dawn or (in her case dusk + X hours).
It was an absolute ****** to set up, but reading the instructions about 40 times, I finally got it to work. Has been working flawlessly for 3+ years.
I think this is the one I used:
http://www.amazon.com/dp/B005H3AXFW/?tag=atomicindus08-20
R
ripperd
Twin Cities, MN
Jackpot. I knew such a thing had to exist, I was just having a heck of a time finding it. In the reviews it sounds like there is a honeywell model that is similar that uses a neutral so I don't have to putz with batteries. I have some leads now, thanks!
Rookie2
Western Pa.
Yes they have them at Lowes/Home depot. They are the size of a dimmer switch and you will need to get your kids to program them ! The screen is 1" square and if you wear eyeglasses as I do you will probably smash the **** out of the wall as you try to learn to program it. LOL good luck ! Set it up on a bench and program it there before you install it .
Rookie2
Western Pa.
ripperd rookie2 has the right idea. I found these when searching for dusk/dawn control for my 3 led decorative garage lights. Going to by one very soon as I am starting my wiring in my garage. They have several astronomical models.
http://www.homedepot.com/p/Intermatic-15-Amp-Astronomic-Digital-In-Wall-Timer-White-ST01K/205478792
If you choose one of these tiny tiny units , mount the switch box at eye level ! They can not be read if your bending over or need additional light !
bobmulry
Coarsegold, CA
Just a thought...............
Why not use a separate Solar Powered LED light or lights and if you want you can also make them motion sensing????????
Many different designs and styles........
No wires, no timer, no electric cost, no muss, no fuss....
Bob
rlev11
I have been using a Honeywell Econoswitch RPLS740B that I got on amazon for a number of years now to power my dual led floodlight fixture on my detached garage (18watt total, costs mt about 70 cents a month). I set it up to come on at sunset, off at sunrise and have not touched it since. It even held its programming through a 3 day power outage a couple of years ago. Just set it and forget it.... The only thing with the switch is you have to have a neutral wire at the switch box
R
ripperd
Twin Cities, MN
Bob
That's an interesting idea. They are on the east of the house though and shaded 90% of the day, I don't think they will get much charge. I use low wattage CFL's anyway, so the electric cost is negligible.
cybrdyke
USA
Intermatic model # EI60MH is the top dog in their family of in-wall dimmers. If you are choosing to use CFL lamps in those lights, use this one. Yes, it costs more. It's got the Astro feature, so it knows when sun-up and sun-down is. Or you can program it to come on at sun-down, and then go off at any specific time you want.
CD
Rod N
Keswick, Ontario
I wonder if I could wire this in so the advertising sign at my business only comes on when I need it?
Couldn't be bothered to change the timer.
