therealaveragej
- Joined
- Jun 2, 2015
- Messages
- 69
A quick video on how I added a functional and cheap dust collection outlet to my router table. Enjoy [emoji1]
[emoji106]Nice! As you probably know by now, it sure makes it a lot nicer to use the table without all of those chips flying around.
Here's what I did a few years ago.
Mounted on a toolbox. That little hole in the front door has a piece of plexiglass on it to adjust the air flow and so I can try to see what's going on in there ....
View media item 16221
Got a couple of vacuum fittings from Rockler to connect to my vacuum system ...........
View media item 16224
Last thing was to mount a "sling" inside to keep sawdust from building up in the corners. Works pretty good .......
View media item 16222
Looks great! What are some affordable dust collection options?
I like that set up. Nice![emoji106] [emoji106] [emoji106]they sell dust collectors, HF has a good one but you'll need to mod the bag to a better filter and plastic on the bottom. It was a popular mod on the woodworking sites back when woodworking was really popular. or you can step up to a cyclone like this one I picked up from a closed shop: you can see my router table setup in the 2nd pic.
I am in the process of putting a small woodworking shop together and was wondering how others have grounded the pvc for dust collection. Can I run a bare copper wire on the outside of the pipe and run screws through the pipe to "pick up" the static?? Or do you run the copper inside the pipe??
Great job on the router dust collector I was wondering if something like that would work. Also I like the idea of the rounded sling. thanks guys
I have noticed that some of the drops, to the machines from plumbed systems, will build static on the outside of the pipes. This happens more during winter when there is less humidity. It would be a good idea to at least ground these drops because it can be quite uncomfortable to be shocked by that.[emoji298] [emoji298] [emoji298]Skip the wire. At first the system will create noticeable static. Soon the dirt and grime on the inside will create a ground path.
