Dw151 chuck removal
Chadwilliam1
Cincinnati
Hello, at work we have a dewalt Dw151 mag drill with a bad chuck. I need some help figuring out how to remove the chuck.
I don't see a set screw in the center.
Thanks Chad
Sent from my LG V30+ using Tapatalk
The Cobbler
the center srew is usually for reversing drills so the chuck cannot spin off in reverse gear
put a large allen wrench into the chuck and a few good smacks counterclockwise whould loosen it. unless it's a tapered shaft ie morse etc
C
Chadwilliam1
Cincinnati
I tried the allen wrench trick and couldn't get it to budge. Judging by the new chuck available on e replacement parts it is not tapered. I will try the allen wrench trick again.
Thnks.
6PTsocket
That usually does the trick. For stubborn cases I put a hex bit on my impact wrench and chuck the hex end in the chuck to be removed. If it is screwed on it is coming off.
