When I'm drilling steel on a DP, if it's a relatively deep hole and I have to peck it (or withdraw the drill to clear the chips), then when I recommence drilling it often feels like the drill bit just dwells for a while and doesn't start cutting straight away. Even when it's just mild steel and is cutting like the proverbial piece of butter, when I recommence drilling it still sometimes seems to dwell without cutting for a while.
The way it seems to go is that I recommence and apply the same pressure as was previously cutting sweetly, but the drill doesn't progress. So I keep applying more pressure and it dwells for a while and then suddenly starts cutting just as easily as before. Often I'm thinking maybe the drill has dulled, and I'm just about to withdraw it and change or sharpen it, then suddenly it starts cutting again and I realize the drill bit is still fine.
BTW. Although I've noticed this in the past, I'd always thought that it was simply the delay in the chips coming up through the hole making it appear to not be cutting when it actually was. However last time it happened I was carefully watching the depth gauge when this was happening, and it really wasn't moving at all.
So now I'm suspecting that I'm leaving too many chips in the hole and that the drill bit is "riding" on a chip and so not being able to bite in, or something like that.
Does that sound like a reasonable explanation?
Does anyone else notice this happen to them too?
