Fordguy1964
Has anyone used dye to find plumbing leaks?
Issue I'm having is that the drain used for our sump pump was routed to the same drain as the washing machine and the utility sink in the basement. I know that my father did the work and was sometimes known for doing things "not quite up to code or up to snuff." I think there was discussion sometime in the past that he had buried 2 55 gallon plastic drums in the yard that were filled with gravel to use as a "filter" for the soap etc. The water went in the top of the first then out the bottom and into the bottom of the second and out the top of the second. The waste water then went out at a ground level drain that ran to a nearby ditch. Since dad was known to tell "stories" I am concerned with a number of things.
1.) The drain for the sump pumps ARE running slow which causes the water to come up out of a floor drain in the basement.
2.) The barrels, if they actually exist, may be the culprit and are backing up with the fats, solids, etc from the clothes washing process.
3.) The water if not going through the "barrel system" may be actually running to my septic system and backing it up. (Although I have not seen any evidence of this in any of the other system of the house.)
I would like to find out if my clothes washer is actually draining to the ditch and get this fixed if this is the case.
I would like to solve the slow draining floor/sump pump drain and allow for the high flow of water.
If I use a plumbing leak finder type dye how much of this is needed to show up? If I use this and the water IS going to my septic system will it ever "percolate to the surface in the yard if the system is working correctly or will I never see it?
The real solution is stopping the water from getting into the house in the first place but that is a next summer project because the ground is too saturated now to do anything about it but bail like a madman! The plan is for a drain tile to be installed around the entire upper portion of the house foundation.
Thanks. I look forward to your answers.
