Dye to trace where sump pump water goes
roc_on_the_rocks
South central Indiana
I'm looking for a dye to add to my sump pump water to help me to trace where that water is discharged. I also want to use this dye on my gutter drains, in order to confirm if they are connected to my sump pump (directly or through French drain).
A friend contractor mentioned such dye is used to trace septic systems. He thought Menards would have it, but no luck. The local plumbing supply doesn't have it either, but graciously offered me a contact that could do that job for me (I'd rather do it myself).
In case this specialty dye is out of my reach (because I'm not a licensed plumber), could you guys suggest alternative color dyes? (I thought about food coloring, but it will get expensive considering the amount necessary).
Thanks as always.
Jmatlock88
How about using the dye used in yard spray equipment?
https://amzn.com/B003ORSXR8
It breaks down quickly in the sunlight so it wont make a huge mess. Although I haven't used this exact brand, the dye is usually very, very potent (don't have to mix a huge ratio to dye the water... 1 oz / gal I think).
Cyberbear
California
Just get the product used to clean toilet bowls that turns the water blue. As I remember it was a tablet that you dropped into the toilet bowl and it would dissolve and make the water a dark blue.
wtfdskin
I have a few bottles. Check with your local wastewater treatment plant. They will have it and may hook you up.
Www.usabluebook.com also has it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
the gypsy
Montreal, Quebec, Canada
I was going to suggest food coloring (been mentioned before) but if you need lots maybe you can try Soya Sauce added to a clean water source (otherwise you may not be able to see the difference)
