DYI Garage Floor Epoxy Coating Attempt
pdids
Hi there,
Looking for advice on attempting a DYI epoxy job on my garage floor. Here is what I have:
1-Slab is 10 years old with several long hair-line cracks.
2-Light to medium broom swept finish
3-No apparent moisture problems
I desperately want to get started on this project but I have so many questions I can't answer and I'm scared to death of screwing it up.
My questions:
1-What product should I use to seal between the floor slab and the foundation wall that epoxy will bond to?
2-Should I use epoxy resin to repair the cracks in the concrete (For example, Sika Sikadur Crack Fix)? Should I chase with a grinder first? Fill with silica sand?
3-Should I first grind the floor with a Diamabush? Will this sufficiently reduce the broom swept finish? If not, can I epoxy over a broom swept finish and get a good result?
4-Was thinking of useing Epoxymaster because I can get it through Costco. The reviews seen pretty good.
Your help would be greatly appreciated!
Garage Flooring
Grand Junction, CO
Hi there,
My questions:
1. Depends on the results you want. For quick aesthetics only some DAP products may do the trick. If you want to construct a seamless membrane that rolls from the floor to the wall and is attractive and functional there are specific products for creating a cove.
2. Hairline cracks, coat them during the install. Cracks, fill them with a gel based crack filler. Large divots, holes, etc, combination of epoxy and sand. Expansion joints or saw cuts, fill if desired, but do so with a gel based expansion joint product.
3. Yes you should grind the floor. I have seen mixed results over broom finish. Take your time.
4. Make sure you use a quality 93-100% solids epoxy, a good primer and high end a good chemical resistant top coat -- varies based on location.
Armorpoxy
Hi
A Diamabrush wont do much to fix a broom finish, it's more designed to scratch up the surface for adhesion. If you are looking to 'smooth out' the floor you need a heavy, professional grinder.
For small hairline cracks and such we carry a Crack Repair Epoxy Putty that works great and can be grinded smooth if you goof a bit, sort of like epoxy spackle. To fix cracks you need something with 'body' as no liquid alone will fix cracks or do a lot of surface repairs.
