Heavymetalmechanic
I got my hands on an Eagle model PV02A wheelbarrow type gas driven compressor. The engine is a write off but I pulled the compressor heads and cylinders off and everything is serviceable. I was looking at a parts breakdown, and it did not show piston pin and connecting rod to crankshaft bearings, is this common on eagle compressors?
This is the link I was looking at:
http://www.eaglecompressor.com/Products/Compressor Pump Breakdown/TT55G-P.pdf
The con-rod and piston pins seem to have a lot of slop side to side, but does not seem to have any slap to them. I would prefer to do a full rebuild on this but do not see any point in digging into the bottom end if I can not replace those bearings. This will be going into service in my garage but will either be sold or given to a friend who needs air.
I would prefer to make my own gaskets and keep the price down on this, probably just clean everything up and hone the bores.
To summarize:
- Are the connecting rod bearings servicable?
- Do you have any stories/experiances with the contractor grade Eagle compressors that you feel like sharing?
- Would it be worth considering swapping this unit (12 cfm@100psi) for the Quincy model 214 (8 cfm@100psi) I am currently running. I have a lot more faith in the construction of the Quincy, but that extra 4 CFM would be handy.
To summarize:
