Easiest way to add 2-20 amp breakers?
weatherby460
Southern WI
What's the easiest way to add 2-20 Amp breakers for new outlets to my existing panel?
Thanks
Yes i see that.
But you need to read the panel label to find out the max # of circuits the panel can have.
Bad Habit
Chumstick WA
It will be something like QO30-40 if it will take tandems. There will also only be certain spaces that will accept them. There will be a slot in the rail in the positions where you can use them.
u2slow
BC
These are the modern QO tandems... come in 15A and 20A.
yeah OP needs to first verify how many circuits the panel can have and whether the panel can take tandems as well as the spaces they can go in
yeah OP needs to first verify how many circuits the panel can have and whether the panel can take tandems as well as the spaces they can go.
I got burned a couple of years ago doing a kitchen remodel of a house built in 1946. Besides no ground wires to most of the house, the QO panel was full and I needed 4 new circuits. Only the bottom 4 spaces allowed tandems so I thought I was in !
FAIL !
Older QO boxes (1980s ?) can not use the current QO tandems and Square D no longer makes the old ones ! Luckily I got the part number from the guy on the Square D hot line and 5 minutes of Googling I found NOS breakers at a very reasonable price.
