Eastwood digital torque wrench?
ChevyZ71
Has anybody used the Eastwood 3/8" drive digital torque wrench? I'm thinking about pulling the trigger on one but not sure, any reviews?
nicksnothereman
In the Mojave
Are these taiwanese or chinese? If it's taiwanese it's probably similar to the kobalt torque wrenches (that aren't digital) and are good, if it's chinese it's probably similar to the craftsman torque wrenches (that are digital) and have mixed reviews.
I think these are knock offs of the cdi models (us made) with different features. If you get one make sure it illuminates good. I'm not a fan of adding tech to mechanical stuff that's just me; I'd use it but doubt it would be any more trustworthy than a clicker or beam because it still will have % error in the measurement even with the digital measurement! (as I understand it):dunno:
robmack
Toronto, CANADA
I'll write up a little review here.
I purchased the Eastwood 3/8" Digital Electronic Torque Wrench (Part number 13630) around November 2013. At the time, I was doing a motorcycle restoration and needed a torque wrench with large capacity at relatively good accuracy over most of its range and that had to read out directly in N-M. I didn't want a wrench whose N-M scale was a mathematical conversion of the ft-lb scale. I also wanted digital rather than click type because I knew that they loose accuracy if not reset to minimum setting after use and I knew myself enough that I'd probably forget. There were several candidates I considered -- Snap-on, Princess Auto, Eastwood, Mac Tools, and Canadian Tire.
I chose the Eastwood over the others based on my personal perceived price / performance ratings. I did a specification comparison but the top candidates were pretty close to make a definitive call. I looked at usability and tried to find reviews for the top candidates. I was finally swayed by Eastwood because of the company's reputation, market penetration and support.
Shipping was fast and the wrench was packaged well. Instructions were clear and the usability of the wrench was what I expected.
I've used the wrench extensively now and think is was a great buy. I have click-type wrenches as well (that this replaced) and this wrench is as accurate in my estimation as these. I love the fact that I don't have to reset the wrench, just turn it off. It saves up to five presets (the value of which I choose) which speeds up changing settings as I torque different bolts. Five preset memory locations is a minimum number, and I'd really like about 8 minimum. The display has a light feature but what really is great about this wrench is the LEDs and the audible signal. As the preset torque is approached, the green led lights and the alarm beeps slowly, becoming faster and the LED turning yellow the closer you get. When the preset is reached, the red LED lights and the alarm is continuous. If you go over, the green led lights again. This feature means you can set torque values without observing the torque value on the display. You can also set a bolt slightly under or over torque based on the alarm or LED display (if you so desire).
The wrench has been reliable. It does not eat batteries for lunch, largely due to its auto-shutoff feature.
There is a model with degree rotation as well as torque setting. I chose not to buy that model because I have no need for rotation measurements on the vehicles I service (my two vintage motorcycle). I'm using this wrench for home mechanic use and not professional use, so I can't comment on its longevity or accuracy over time with continuous use.
In short, I would recommend the Eastwood 3/8" torque wrench.
dnschmidt
Phoenix, AZ
I have the Eastwood digital torque wrench in the 3/8" version. Mine is the angle version. Here's the story. The torque wrench part of the tool is outstanding and dead accurate. The angle part completely blows. Great torque wrench hopelessly bad torque angle wrench.
