Easy Access Car Dolly
Highland
Oklahoma
Has anyone used them?
Used to be made by Backyard Buddy but seems to be OOP.
Instead of going under the tires like the common "skates" they went under the axle or frame and were adjustable for different vehicles.
metaleltr
Western Ohio
Unidolly part number 1204300 or Champ part number 7172 may be similar to what you are looking for. Fairly common in body shops for situations where the suspension has to be removed to complete repairs.
GForceJunky
Not OP but I didn't know these existed. Sweet! May have to grab a set...I'd have had a lot of use for these in the past.
H
Highland
Oklahoma
Those are a different design, but probably target the same market. And largely do the same job. I think the Easy Access ones will hold the chassis up higher, if that is a good thing!
GForceJunky
Interesting. I kinda want to build my own now and incorporate a bottle jack or similar to be able to lift/lower the car on the dollies. Use pins to secure once desired height is reached (a la Enco-style jackstands).
bas157
Near Philly
Never seen those before. What I've done at home....I've got dollies that go under each tire. I just built a platform out of 2x4s that site on top of the platform and just put a jackstand on each dolly. Worked good enough for me and cost was just some lumber and screws.
